Clutch line fluid viscosity?
Old 09-12-2004, 08:27 PM
Xgen's Avatar
Default Clutch line fluid viscosity?
What viscosity fluid do you guys use? i heard that a heavy fluid makes it a bit stiffer, and a light fluid does just the opposite. just wondering what is a good fluid to use, i want my clutch pedal to be stiffer.
Old 09-12-2004, 08:31 PM
CivicVX94's Avatar
Default Re: Clutch line fluid viscosity? (honda_guy_83)
I recently put in some 10w30 from the dealer and it feels great
I'm not sure what grade or brand but I'lll check later if you care
Old 09-12-2004, 08:38 PM
Xgen's Avatar
Default Re: Clutch line fluid viscosity? (CivicVX94)
Alright, let me know, thanks.
Old 09-12-2004, 09:00 PM
nocturnaldragon's Avatar
Arent you sapossed to use brake fluid in this case not oil? the stiffness would be in how you bleed the system i would think just like the brake system. Then again i could be wrong but using conventional motor oil for this app dosent seem right to me....
Old 09-13-2004, 06:56 PM
CivicVX94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_guy_83 &raquo;</TD></TR><TR><TD CLASS="quote">Alright, let me know, thanks.</TD></TR></TABLE>
I feel like an *** now, my dad threw away the bottles already and he's in bed so I can't ask him what brand it is. Sorry But i'll find out tomorrow for sure. and fyi i tried 3 car shops and none had it and we eventually had to go to the honda dealer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocternaldragon &raquo;</TD></TR><TR><TD CLASS="quote">Arent you sapossed to use brake fluid in this case not oil? the stiffness would be in how you bleed the system i would think just like the brake system. Then again i could be wrong but using conventional motor oil for this app dosent seem right to me....</TD></TR></TABLE>
that's why you don't own honda this isn't an opinion, it's a fact. It's what honda says goes in their tranny's. I do remember hearing brake fluid too but ask the dealer and you'll hear otherwise.
*edit* you have the engine i want
Old 09-13-2004, 07:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 &raquo;</TD></TR><TR><TD CLASS="quote">
What the heck are you talking about??? I thought he was referring to what you put in the lines for the clutch which is hydrolic fluid. Aka brake fluid or Atf fluids. As for the tranny yes honda USSED to recomend using motor oil but now they have something just for manual trannys they recomend. Yea my engine sucks tho its tooo slowwwwwwwwwwwwwwwwwwwww
Old 09-13-2004, 08:53 PM
Two_K Si's Avatar
Default Re: Clutch line fluid viscosity? (nocternaldragon)
ATE super blue made by clutch bite harder than a fat German boy.
Old 09-14-2004, 10:53 AM
CivicVX94's Avatar
dude all i'm saying that i went to the honda dealer like 3 or 4 days ago and asked the dealer transmission fluid or what they recommended for a honda tranny and I got some 10w30 oil right there. I can't remember the grade but that's what it is, I know that their is Honda MTF but they didn't recommend it. I'm just saying facts man chill out
Old 09-14-2004, 11:28 AM
Sliced Beard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 &raquo;</TD></TR><TR><TD CLASS="quote">dude all i'm saying that i went to the honda dealer like 3 or 4 days ago and asked the dealer transmission fluid or what they recommended for a honda tranny and I got some 10w30 oil right there. I can't remember the grade but that's what it is, I know that their is Honda MTF but they didn't recommend it. I'm just saying facts man chill out</TD></TR></TABLE>
dude, / yourself
he is asking what the viscosity of <FONT SIZE="3">CLUTCH FLUID</FONT> (otherwise known as hydraulic fluid) is not what the viscosity of tranny fluid is.
(Honda uses and RECCOMENDS Honda MTF which is nothing but 10w30 with special friction reducers designed especially for brass and hardened materials)
your clutch uses a form of hydraulic fluid.....any DOT 3 or DOT 4 will work just fine in your clutch system, but like said above <FONT COLOR="blue">SUPER BLUE</FONT> kicks ****
Old 09-15-2004, 06:14 AM
Xgen's Avatar
Thanks for the help guys, where could I get some of this super blue stuff youre talking about?
Old 09-15-2004, 06:28 AM
Default Re: (honda_guy_83)
ATE Super Blue can be found on Ebay quite readily.....here is a link to listings
Ebay, Super Blue
Old 09-15-2004, 08:05 AM
Default Re: Clutch line fluid viscosity? (DirtySol)
So how is super blue so much better? what does it do differently then hysro fluid i thought it would all work the same.
Old 09-15-2004, 08:15 AM
quality control standards....better additives....there are a bunch of things that make a difference on fluids. Just like oil is oil but different manufacturers have better oil because of QC and manufacturing processes
Old 09-15-2004, 08:41 AM
sil
sil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol &raquo;</TD></TR><TR><TD CLASS="quote">quality control standards....better additives....there are a bunch of things that make a difference on fluids. Just like oil is oil but different manufacturers have better oil because of QC and manufacturing processes </TD></TR></TABLE>
i would think ATE superblue would be unnecessary to use as clutch fluid, by all means if this is what you have lying around use it, but ANY brake fluid will be fine.. you think the clutch goes through the heat and abuse that brakes do?
Old 09-15-2004, 08:49 AM
Default Re: Clutch line fluid viscosity? (sil)
it compresses less than any ole' brake fluid
B16AGUY
07-13-2009 03:01 PM
explictness
02-21-2007 08:37 PM
Flava
08-15-2006 09:33 AM
in-n-outboy
09-29-2004 09:40 AM
John
07-28-2003 04:24 PM
Quick Reply: Clutch line fluid viscosity?
