floor jack height
Old Nov 22, 2001 | 07:26 PM
00b18b's Avatar
Default floor jack height
im thinking about getting a floor jack but im not sure what height clearance i should get. would a 15in ground clearence floor jack be good enough to get under the teg?
Old Nov 23, 2001 | 02:09 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: floor jack height (autoLS)
Find a SUV jack that has a lift heighth of 21".....
You thank me/yourself if you ever have to pull the tranny.
Old Nov 23, 2001 | 02:11 AM
ingrate's Avatar
25 Year Member
Default Re: floor jack height (Mista Bone)
ideally you want one with a starting low clearance of ~4" and goes up past like 22" so you can fit jackstands and stuff under there..
Old Nov 23, 2001 | 08:36 AM
ndustryalGSR's Avatar
Default Re: floor jack height (In7egrity)
It took me forever to find an affordable hydraulic floor/shop jack with a low enough clearance to fit under my car, and I only have Eibach Pro-kits. I actually ended up getting one a Pep Boys that was mis-priced. It's a big, 3 ton capacity jack, with great features -- picked it up for only $50. Most of the good ones I found, with proper clearance, cost $200+. Also, in most of my experience, most of the "SUV" jacks wouldn't fit under the car, but most other normal jacks still lift high enough for jackstands to fit under the car.
Good luck.
Jet.
Honda Fit
10
May 14, 2007 05:36 AM
tekstyle
Jun 14, 2006 07:40 PM
Yellow Dragon
Honda Fit
12
Apr 29, 2006 04:27 PM
Stock R
May 11, 2003 11:54 AM
broke
Mar 10, 2002 03:56 PM
