first mod to do
Old Apr 26, 2005 | 11:55 AM
  #26
1GreyTeg's Avatar
Default Re: first mod to do (slperhybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slperhybrid &raquo;</TD></TR><TR><TD CLASS="quote">i have a 93 integra ls what is the first thing i should do to the car, so far all i have done has been to clean it out real good but other than that its stock, i know i need a new exhaust because mines is rusted what do you think i should go for any ideas???</TD></TR></TABLE>
Go over the car with a fine tooth comb, do all maintenance that is required (timing belt, water pump, valve adjustment, etc) as well as general services (fluid changes, oil, coolant, tranny, filters, oil, fuel, air, etc).
then
Check out some aftermarket catbacks that you find appealing both visually and sound wise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slperhybrid &raquo;</TD></TR><TR><TD CLASS="quote">any other things i might be able to do to make it faster?
thanks in advance</TD></TR></TABLE>
Modify the driver first.
Take it to a local autocross or HPDE.\
Good luck
Old Apr 26, 2005 | 12:53 PM
  #27
TeaAddict's Avatar
since your exhaust is rusting, you will look to replace it.
things to consider:
goals (n/a, f/i)
sound (loud, quiet)
style (cannister, muffler)
after you tell us this, we can help you a little bit better.
i think you should get a k&n drop in air filter and open up your air box.
Old Apr 27, 2005 | 10:49 AM
  #28
TypeRobert's Avatar
Default Re: first mod to do (TeaAddict)
ok suspension i got what i said i would the ones i mentioned above, i want to go na with this car, and i would like a catbak that was quiet but gets loud when i open up the car sort of what my friends apex world series sounds on his ITR. intake i'll try to get one locally and i am waiting for the tracks to open to go to the races friday night but also know that i dont plan on a race car just a sleeper rice killer yeah well thanks for the feedback
Old Apr 28, 2005 | 06:11 AM
  #29
neoteg11's Avatar
if this is your first tuner start slow. lower and replace the stock breaking system, the entire system.
lilmonkey
Feb 11, 2006 05:05 AM
TegraBoy
Apr 22, 2004 06:45 PM
DarkMortisX
Dec 6, 2003 06:10 PM
teg969
May 14, 2003 05:14 PM
743motorsports
Oct 9, 2002 10:59 AM
