Firewall
So I'm installing my zex kit right now and I can't find a hole in the firewall to run wires from the engine to the cabin. I have a 95 LS
Do I need to drill a new hole or is there a good one I'm not seeing?
Heres one...but is intended for amp installations...
Courtesy of team-integra.net
EDIT** thats the same firewall plug that most people use to plug up the integra rear wiper hole once removed.
NRG
NRG
I use the the tube where the A/C drains through the firewall. Look under the car, you'll see a rubber hose that just dumps on the ground, I'm pretty sure it's for the A/C condensation to dump. You can run wires side-by-side with it.
-PHiZ
-PHiZ
Linked
Feb 15, 2010 07:27 PM
one slow coupe
Dec 26, 2004 12:24 PM
