Failed smog, help
Old Oct 28, 2010 | 11:06 AM
mikespike2's Avatar
Default Failed smog, help
Hey guys,
I took my car in for a smog today. It failed on two of the 15mph tests, HC and NO. I suspect the front O2 sensor making it run rich? I think the cat is good since it didn't fail all of the other tests as well. Also I'm not sure what that note about OBD tests means, there is no CEL on.
I recently replaced the spark plugs. I also checked the timing and it is right on the red dot on the crank pulley.
I attached the results. 15mph HC: 80 and NO: 695.
Let me know what you think.
File Type: pdf
Old Oct 28, 2010 | 12:23 PM
vpower101's Avatar
Default Re: Failed smog, help
hey man im a smog tech and from what i see it looks like your cat was not hot enough. i say this because the 25 mph numbers are much lower if there was anything wrong the 25 #s would defiantly be higher. my suggestion is to drive the car hard before u go to the test spot and dont let the car set to long before the test. if theres a line come back when there is no line so your cat doesnt have time to cool off. also u need to drive the car around 60 miles to clear out the readiness monitors so it will pass the obd functional test. hope this helps... goodluck
Old Oct 28, 2010 | 07:02 PM
mikespike2's Avatar
bump
My_EFsedan
Nov 18, 2009 06:54 AM
Nicks95GSR
May 21, 2008 07:37 AM
GSRacer1
Oct 9, 2003 10:40 AM
SimbaDogg
Jul 2, 2003 09:17 AM
hndarcrb18c1
May 4, 2003 08:59 PM
