Factory matched Paint
Old Feb 5, 2005 | 04:44 PM
JAI-DM's Avatar
Default Factory matched Paint
Anyone know where to find factory matched spray paints at? I know duplicolor and other companys make them, but I cant locate any in my paint code. B-97M which is 2001 Integra Voltage Blue. Any help would be great.
Jai
Old Feb 5, 2005 | 04:54 PM
Moogen Powah's Avatar
Default Re: Factory matched Paint (INTEGRAJAI)
http://paintscratch.com/ Haven't used them myself, but have seen positive things about them on H-T.
Old Feb 5, 2005 | 05:50 PM
JAI-DM's Avatar
Ya I saw them too, anyone know of any more local type shops that stock these?
Old Feb 5, 2005 | 06:01 PM
Monkey Z.'s Avatar
i used paintscratch.com ... they match down to tha VIN number
Old Feb 5, 2005 | 06:27 PM
JAI-DM's Avatar
Default Re: (DarkblueInteg)
So with them it turns out to be a perfect match then? I have heard that the Voltage blue is a really hard color to match, any ideas?
Old Feb 5, 2005 | 07:55 PM
Monkey Z.'s Avatar
preety much a perfect match yea... i couldn't find adriatic blue pearl at any shop so i bought some from them.
Old Feb 5, 2005 | 09:08 PM
Lord Helmet's Avatar
Default Re: (INTEGRAJAI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INTEGRAJAI &raquo;</TD></TR><TR><TD CLASS="quote">So with them it turns out to be a perfect match then? I have heard that the Voltage blue is a really hard color to match, any ideas?</TD></TR></TABLE>
I don't have any problems with them either. my color firepepper red pearl metallic is a hard color to match perfectly but when I ordered from them.......volia! perfect match. besides if they don't match it up the first time, they'll redo it for you free of charge can't beat that!
Old Feb 6, 2005 | 10:03 AM
JAI-DM's Avatar
So I assume since their page says my car REQUIRES a basecoat and a clearcoat, I HAVE TO order both? Any clues if I HAVE TO order their specific primer as well?
Old Feb 8, 2005 | 04:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INTEGRAJAI &raquo;</TD></TR><TR><TD CLASS="quote">So I assume since their page says my car REQUIRES a basecoat and a clearcoat, I HAVE TO order both? Any clues if I HAVE TO order their specific primer as well?</TD></TR></TABLE>
You only have to buy the primer IF your paint is chipped to the point bare metal is showing then you need the primer. for the basecoat and clearcoat, I HIGHLY recommend using both because if you only use the basecoat you will get that cheapass 1-Day Paint/ Macco semi shine/dull look on your paint. The majority of modern cars nowadays uses a minimum of 2-stage paint: basecoat and clearcoat. The clearcoat is what gives it the shine.
BTW click in the icons on that specific website and it will tell you exactly the same thing I just told you.
Old Feb 8, 2005 | 08:05 PM
JAI-DM's Avatar
Thanks sleeperciv!! Good info!
Jai
HATCHBACK GORILLA!
Feb 25, 2008 06:33 PM
DOHClessEF-9
May 12, 2005 05:21 AM
phatrick2332
May 2, 2005 07:42 AM
FlipSkater
Aug 26, 2004 04:55 PM
Drum_Guru
Jul 15, 2003 07:28 AM
