Extremely low compression?!
Old May 20, 2018 | 09:16 PM
  #26
WestyNaut92's Avatar
Default Re: Extremely low compression?!
Originally Posted by Lord Orange
Education is priceless.
it is only 75-150$ to pressure test and resurface. Now you get to do the job again. I don't understand on mission critical items like the minimum of a cylinder head pressure test. Your last move doesn't allow for any to further diagnostics besides removing the cylinder head again. Good luck with repair.
I literally could not afford to do that. Like I wish I could have. Also I was doing the repairs at a friends house and I could not leave my car in their garage to get my head resurfaced and pressure checked.
I appreciate your input and I agree that I should have done that.
Old May 20, 2018 | 09:42 PM
  #27
Also, I should add, it’s only cylinder four that’s doing it. Ignition coil, plugs, wires, cap, and rotor are all new.
(Also I did the quick and dirty test of pulling each plug wire as it’s misfiring and see if anything changes. Sure enough, it’s cylinder four.)
I suppose next I could bring it to a shop and see if they’ll do a leakdown test for me...alternatively, is swapping injectors a good idea? (Like, move #4s injector over a cylinder and see if the misfire changes places?) Last I checked my fuel system was within spec of fuel pressure.
Old May 20, 2018 | 09:55 PM
  #28
Lord Orange's Avatar
Fuel.........spark........compression
three things needed for an 4 cycle, gasoline engine to run.
so quit beating around the bush. What is compression after correct vavle lash and head gasket replacement?
Old May 20, 2018 | 10:02 PM
  #29
I’ll check tomorrow when I have spare time before work.
I don’t quite appreciate your attitude towards me. I’m not an idiot, and I don’t like being treated as one. Apologies if I’m misreading that, you can’t tell tone through text on a screen.
Old May 21, 2018 | 05:33 AM
  #30
CandyRedRC46's Avatar
Well he is being hard on you, but he is right.
Do it right and do it once.
But, try to save money, cheap out/ do it wrong, you will have to do it again and wind up paying twice.
Take your time and do it right. Even if it means you need to take the bus and eat ramon for an extra week or two. It will save you in the long run....
Old May 21, 2018 | 04:58 PM
  #31
tamboo's Avatar
10 Year Member
yeah eat ramon to earn a little extra on the side.
i hear he tips well! 8)
Old May 21, 2018 | 05:20 PM
  #32
bahahahahaha that made me laugh, thank you. Also I know it’s not a fuel issue now, as I swapped cylinder 4s injector with 3 and the misfire stayed in 4. So, we’re looking at either a warped/cracked head, or bad rings. Given the bore was stupid smooth (well, I mean, at 200k, I’d bet all that cross hatching has been worn down). I’ve got a lead on running b18a1 for pretty cheap, which I may just swap in to keep the car driveable and learn how to rebuild a motor the correct way. I appreciate all the help I get on this forum.
stir_fry_boy
May 15, 2018 06:27 AM
vtechjunkie
Apr 20, 2010 05:52 AM
Tyteg
May 16, 2007 07:30 AM
portenio78
Jul 18, 2005 05:40 AM
greenli0n25
Jan 26, 2004 07:29 AM
