expected gains?
Old Feb 11, 2006 | 09:52 AM
petergriffen's Avatar
Default expected gains?
how much should i expect to gain from this setup:
plans: crower stage 2 street/strip
crower valve springs and reatainers
crower valves
skunk2 cam gears
ported head
im goin to also keep the stock redline, till i can rebuild the bottom end
current setup : 95 ls with aem sr intake dc sport 4-1 test pipe and 2.25 piping
Old Feb 11, 2006 | 09:57 AM
ichbinsobose's Avatar
Default Re: expected gains? (petergriffen)
10-20 hp with a tune. Without one, don't bother. I'd say you get 12hp.
Old Feb 11, 2006 | 10:01 AM
krazyteg's Avatar
Default Re: expected gains? (ichbinsobose)
I have seen a setup similar to that hit 150 whp, which is pretty good considering stock LS's come with about 110 whp from the factory.
Old Feb 11, 2006 | 10:54 AM
TurboTeG4's Avatar
Default Re: expected gains? (krazyteg)
How much does all of that cost, for 10-15 whp, get a turbo for the same price 10-15 whp you cant even feel that.
Old Feb 11, 2006 | 11:06 AM
krazyteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazyteg &raquo;</TD></TR><TR><TD CLASS="quote">I have seen a setup similar to that hit 150 whp, which is pretty good considering stock LS's come with about 110 whp from the factory.
150-110 = 10-20???
Old Feb 11, 2006 | 06:07 PM
Default Re: (krazyteg)
im doin this so i dont blow my enigine from turbo. turbo is in my fututer
Old Feb 11, 2006 | 07:29 PM
Uncle Willie's Avatar
Default Re: (petergriffen)
Dude, just do a rebuild with stock parts except pistons and connecting rods. Then turbo it at 7-9 psi. It WILL be reliable.
You dont want to run stage 2 cams on a 9.2: compression ratio.
Old Feb 11, 2006 | 09:25 PM
runeminaEF9's Avatar
Default Re: (RIP Indian Larry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIP Indian Larry &raquo;</TD></TR><TR><TD CLASS="quote">Dude, just do a rebuild with stock parts except pistons and connecting rods. Then turbo it at 7-9 psi. It WILL be reliable.
You dont want to run stage 2 cams on a 9.2: compression ratio.</TD></TR></TABLE>
thats what i'm sayin. ^ you wont benefit as much from the cams because of the lower compression ratio, plus you have to consider the airflow capabilities of the LS head, versus a b16 head. theres more potential with an lsvtec or turbo setup then there is with what you want. its your decision in the end, but if you want more bang for your buck, then the above reccomendations will suit you better.
just remember, lots of power costs lots of money. if you dont have lots of money, then its wise to seek out the most cost effective and reliable way to make power.
Old Feb 12, 2006 | 05:57 AM
Default Re: (runeminaEF9)
i have the cams and and skunk2 intake manifold should i sell those and go ls/vtec
Old Feb 12, 2006 | 06:17 AM
JCushing's Avatar
if your intending on turbo in the future those cams will pay off huge when you do. LS cams suck ***** for NA and turbo.
i wouldnt expect more than 140-145hp with stock compression though. maybe 150 with a ported head. swap in some b16 or jdm R pistons though and youll see 150-160
why the stock redline though? if you upgrade your valvetrain you can take it to 7500 on a stock block.
also dont listen to anyone that says just go vtec cause 99 out of 100 times they dont actually know what they are talking about
Old Feb 12, 2006 | 02:01 PM
Default Re: (JCushing)
ok well i think im goin to stay with my original plans and tyhey are as lists
crower valve springs and retainers
crower valves
ported head
crower connectoin rods
aftermarket pistons ( havent decided on which ones yet )
turbo kit (havent decided on which one yet either)
if i should do anything else please tell me
Old Feb 12, 2006 | 03:10 PM
mystikalstriker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">if your intending on turbo in the future those cams will pay off huge when you do. LS cams suck ***** for NA and turbo.
also dont listen to anyone that says just go vtec cause 99 out of 100 times they dont actually know what they are talking about</TD></TR></TABLE>
properly built lsvtec WILL cost more then a good turbo set up. So in the end the darkside is the most cost effective way to go.
EG6 Poe
58
Jul 31, 2008 11:43 PM
littlegreenb18
Aug 28, 2006 10:46 PM
slowteg550
Apr 16, 2006 03:55 PM
boostin b16
Oct 8, 2003 05:16 PM
