exhaust question
Re: exhaust question (STUCKED)
The 00-01 GSR has a different length header (because they added an o2 sensor to the header - 1 in the cat and 1 in the header), so the exhaust length is the same as the 94-01 LS. The 94-99 GSR on the other hand has no o2 in the header, and either 1 or 2 in the cat (depending on 94-95 (obd1) or 96-99 (obd2)) so the exhaust piping does not fit on the 00-01 GSR or 94-01 LS.
Re: exhaust question (purplegsr (Exospeed))
so im in the process of buying that eshaust anf its for a 01 gsr, will it fit? mines a 95
so i found that its for an '00 gsr. will it fit? or could i do some kind of customizing to make it fit?
It will fit with customization, I believe you will need to extend the 00 GSR exhaust piping slightly to mate with your 95 header/cat. Nothing a regular muffler shop couldn't do in 20 minutes - they will either cut your 00 exhaust, add a section of pipe, and reweld the flange onto the end, or they could make a small section of pipe with 2 flanges on it that would connect to your cat on one side and your exhaust on the other. The 2nd option would be more expensive.
would a test pipe which eliminates the cat. cont. work making it a little longer work?
just hit up kteller8 or smsp on this board - they will make a testpipe for you. As for locally, just find a muffler shop and tell them what kind of flanges you need and how long, and they will usually make it for you. Most won't put it on your car, because then they are committing a crime, because if you drive the car in they know it's not for offroad use. Don't even bother calling Midas or anywhere corporate owned.
Re: exhaust question (MITSUBA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MITSUBA »</TD></TR><TR><TD CLASS="quote">If your using just the exhaust it should fit without any problems.</TD></TR></TABLE>
No it won't, the 00 GSR exhaust does not fit on a 95 GSR without modifying the length. If he had a 95 LS, the 00 GSR exhaust would fit fine.
Re: exhaust question (SMZ GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMZ GSR »</TD></TR><TR><TD CLASS="quote"> to purplegsr for giving you all the correct info.
I was going to chime in but you already covered it all </TD></TR></TABLE>
Thanks, only took me 6 posts, a new record.
Send a PM to kteller8 or smsp on H-T, or go to http://www.kteller.com
jonnybravo
12-27-2003 10:21 PM
