Exhaust
Old Jul 8, 2003 | 11:31 AM
BIntegra99's Avatar
Default Exhaust
What should you use to get off the rusty bolts of an old exhaust system. In particularly the ones that connect the exhaust to the cat.
Old Jul 8, 2003 | 11:33 AM
dohc-nyne's Avatar
my freind used a grinder lol the circulaur power kind
Old Jul 8, 2003 | 11:35 AM
AllmotorJunkie's Avatar
Default Re: Exhaust (BIntegra99)
Just torque the f*ck out of it and it should fall right off. I just had to do that to (2) of my exhaust spring bolts at the rear section of my stock exhaust system.
IntEGNYC's Avatar
Default Re: (dohc-nyne)
once they are seized, you wont be able to take them off. Its a common thing for the exhaust. You might have to cut them and put new ones on.
Old Jul 8, 2003 | 12:05 PM
BIntegra99's Avatar
Default Re: (IntEGNYC)
What would I cut them with ?....And how would i get the ones off that connect to the cat ?
Old Jul 8, 2003 | 01:11 PM
VTEC-DA's Avatar
Default Re: (BIntegra99)
A grinder. And the ones are welded to the cat, they dont come off without ALOT of effort. I grinded off the threaded part, then heated up the head that is welded to the flange on the cat, and pounded the **** out of it and they eventually popped out.
Old Jul 8, 2003 | 01:26 PM
acuraholic's Avatar
Default Re: (VTEC-DA)
Or you could TRY soaking them with WD40 overnight. It's worth a shot. You'll probably have to grind or torch them, though.
aaronhume
Dec 3, 2010 05:22 PM
B18c1vicrx
Oct 1, 2007 07:44 PM
sohctodohc
11
Mar 26, 2007 11:21 AM
TheWelderGuy
Feb 14, 2006 04:28 PM
