everything needed for a gs-r engine in an ls???
Subscribe
May 13, 2002 | 12:48 PM
i have a 94 ls integra 5sp. i have 130k miles now. my engine now burns a little bit of oil, which isnt too bad considering the miles. well i want to swap the engine with a gs-r with LOW miles. I wanted to know what is needed. I want to know everything down to the last nut and bolt. (ecu upgrade, oil pump, ETC.) Also where can i get a Gs-r engine for a pretty good price. *Keep in mind i am on kind of a low budget. Any other coments are welcome
Reply 0
May 13, 2002 | 06:18 PM
Re: everything needed for a gs-r engine in an ls??? (1hotintegra)
ttt
Reply 0
May 14, 2002 | 07:13 AM
I you get a complete changeover you dont have to worry about anything. You only have to run the VTEC wires, oil pressure, knock sesnsor and you're done.
Just make sure you use a GSR tranny and not a LS cause you'll be dissapointed between shifts not being in VTEC range.
Good luck
Reply 0
May 14, 2002 | 08:05 AM
Re: everything needed for a gs-r engine in an ls??? (b18bvtec4drteg)
i really dont have the money for the WHOLE change over i was thinking as little as possible u know, just engine, tranny and?????
Reply 0
May 14, 2002 | 09:47 AM
ecu also.
Reply 0
May 14, 2002 | 09:59 AM
Re: everything needed for a gs-r engine in an ls??? (nsane-ls-rr)
how much does a swap like that usually run, icluding parts n labor?
Reply 0
May 14, 2002 | 10:04 AM
Re: everything needed for a gs-r engine in an ls??? (BriansDC4)
they have gotten cheaper in the last year, prob around 3k for a total swap. Less for a non-complete swap
Reply 0
May 14, 2002 | 10:30 AM
Re: everything needed for a gs-r engine in an ls??? (97blackteg)
where can i order, a non complete swap i have an ls so i want as little as posibble only waht i need
Reply 0
May 14, 2002 | 10:31 AM
Get a GSR engine and your set. I have seen them from $2000-$4000 depending on miles and condition. Look into overseas as well maybe you can get hooked up with on of those engines because I believe in like Japan the law is 30,000 miles on a car then they have to get a new engine.
[Modified by Fooser, 8:35 PM 5/14/2002]
Reply 0
May 14, 2002 | 10:42 AM
Re: everything needed for a gs-r engine in an ls??? (Fooser)
If you plan on turbo, run the GSR motor on the LS tranny, and just get the GSR ECU, wire it all up and you are set, but I am not sure about the power assist steering on the LS tranny I know that the G2 integras had the power assist steering, but im not sure on the G3 tegs. Anyone?
Reply 0
May 15, 2002 | 05:57 AM
Re: everything needed for a gs-r engine in an ls??? (riceboy)
ttt
Reply 0
Subscribe
