engine troubles
Old Nov 18, 2001 | 01:21 PM
KanzenR95GSR's Avatar
Default engine troubles
I recently was racing and missed a gear and redlined pretty good. good enough to make my car idle like its about to stall and my valves are clicking louder than usual. So i took it in to a local repair shop to get my valves adjusted and timing and idle set. . . first they said the problem was a failed #3 injector then replacing the injector wasnt the problem so they did a leakdown test on the #3 piston and found out it only had 135 psi of compression. now they are leaning towards a crack in my head. . .anyone have any input on what i did to my motor? any input would be helpful.
Old Nov 18, 2001 | 02:05 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: engine troubles (KanzenR95GSR)
bent valves. did they do a leakdown ot just compression test?
my guess is a bent valve.
IRFertl
May 22, 2004 07:19 AM
RGoose18
May 21, 2004 10:13 AM
BamaGSR
Mar 29, 2004 07:16 PM
JdmIntegra98
Jul 3, 2003 03:58 PM
8400 rpm
Jul 28, 2002 08:57 AM
