engine trouble ... please help
Old May 11, 2004 | 01:22 PM
kiang's Avatar
Default engine trouble ... please help
my check engine light's on and the code says emission control system insufficient purge flow, or something like that. i was wondering what this meant, how bad it is, and what i can do to fix it ... thx!
Old May 12, 2004 | 04:33 AM
JimBlake's Avatar
Default Re: engine trouble ... please help (kiang)
More info... What year is your integra? What's the code number? Generally there's a handful of components to check, plus it might be bad wiring connections somewhere. Of these, maybe one is a common failure, but check to be sure before replacing a $50 valve...
If it's EVAP purge flow, that sounds like you have an OBD-2 car. (OBD-1 doesn't measure for that.) Hopefully someone with a Helm book can say...
Old May 14, 2004 | 02:52 PM
kiang's Avatar
Default Re: engine trouble ... please help (JimBlake)
i have a 96 integra, RS, the code was 92, i think it's evaporative emission control system insufficient purge flow, and that's about all i know about my car ... anyone that could help me further would be greatly appreciated.
Old May 14, 2004 | 03:31 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Tighten your gas cap and reset the ECU.
Old May 27, 2004 | 03:39 PM
kiang's Avatar
Default Re: engine trouble ... please help (integra707)
wil tightening my gas cap really work, i've reset my ecu numerous times and the check engine light keeps coming back. i don't know what else i can do .....
Old May 28, 2004 | 03:39 AM
JimBlake's Avatar
They changed the EVAP system a LOT between my '95 & your '96. In '95 they didn't even HAVE a code 92. So you probably want to get your hands on a Helm book for your car. It'll have a pretty detailed procedure for checking out each piece of that system.
My_EFsedan
Nov 21, 2008 08:25 PM
jeremy8886
Dec 7, 2005 06:54 PM
96integralsgreen
Sep 30, 2004 01:58 PM
Philbert
Jul 10, 2004 05:44 PM
TurboedGSR
Aug 21, 2002 11:37 AM
