Engine swap problems PR4Y and P75
Old Mar 2, 2012 | 05:20 PM
fivestarsi's Avatar
Default Engine swap problems PR4Y and P75
Hey guys im swapping the motor out of my 95 integra with a B18B1 from a 98 integra. While switching over the intake manifold I noticed that there is a little black canister thing where the hose connected to the pcv valve connects to behind the block. This canister has a hose at the top of it that connects to an outlet on the 95 b18b1 block and an opening at the bottom as well. The 98 b18b1 block doesnt have these openings. So where does the pcv valve supposed to connect to? I need this to pass smog so any help will be appreciated.
95 b18b1 has PR4Y head and 98 b18b1 has P75 head. Not sure if this helps.
Old Mar 2, 2012 | 06:06 PM
fivestarsi's Avatar
Default Re: Engine swap problems PR4Y and P75
***UPDATE***
Figured out that the pcv valve plugs into the top of the valve cover on the obd2 b18. So Im assuming I just have to run the hose straight to the intake manifold. Hope it passes smog this way
lancerkid06
Mar 11, 2024 09:53 AM
THE LORD OF CHAOS
May 5, 2008 02:55 PM
Enta
Jan 29, 2007 03:51 AM
Turbochargedcivic
Aug 2, 2006 08:04 AM
THE94GSR
Oct 20, 2003 08:10 PM
