ENGINE SWAP
Old Mar 10, 2004 | 12:35 AM
94rsvtec's Avatar
Default ENGINE SWAP
trying to get a sohc vtec into my dohc non vtec. basically a b16 vtec into my ls non vtec. i heard that my tranny will bolt on to the b16 ecause all b seires are compatible. people are telling me that i will need 4 wires going to my ecu to the engine. 2 wires for the vtec solenoid and 2 for the o2 sensor. is that true? also, i heard that my obd1 harness will b compatible wit the b16 .. please help! thanks!
Old Mar 10, 2004 | 12:41 AM
94rsvtec's Avatar
Default Re: ENGINE SWAP (94rsvtec)
anyone kno anything about this???
Old Mar 10, 2004 | 12:47 AM
jDMJeRk's Avatar
is it possible to put a sohc vtec head on a dohc bottom end?
I think what your talking about is putting on a dohc vtec head on your ls bottom end. I dont know a lot about it; but there is some re-rewiring to do; the trannys are interchangeable as long as they are hydro/cable or you convert to one or the other and the axels line up right; depending on the year of your ls will depend on wether or not you cause your your harness....there just some food for though; search and youll find much much more
Old Mar 10, 2004 | 01:43 AM
Nsx408's Avatar
b16 is a DOHC vtec not SOHC... and i wouldnt waste the money... your car will be to heavy for a 1.6 ... just get a head and go LSVTEC... and yes you have to add wires for the VTEC to work with the new ECU you will be putting in...
Old Mar 10, 2004 | 06:13 AM
94rsvtec's Avatar
Default Re: ENGINE SWAP (Nsx408)
isnt the b16a the vtec engine that comes wit the del sol si? i have a itnegra rs, the lightest integra model. evven with my stock engine, i rape the **** outa cars wit more hp than i. the b16 has 160 hp and 8200 redline rite? if i had that in instead of my ls engine, i think my car would b much faster so basically, POOR BOYS GSR
haha
Old Mar 10, 2004 | 07:38 AM
patmcd's Avatar
there are two vtec models dels sol's. One is the Del Sol Si, which has a d16 sohc vtec. The other is the Del Sol vtec, which has a b16a3 in it. As far as making your car faster.....you gain 20hp, but you lose torque.
Old Mar 10, 2004 | 12:15 PM
94rsvtec's Avatar
Default Re: ENGINE SWAP (patmcd)
im getting the b16a.. the one that comes in civic si's can someone tell me the specs on that engine? i raced a civic si beore and i lost. i only have around 500 dollars to spend on a engine. JUST THE ENGINE, i dont need a tranny because im planning on buying an engine that will swap perfectly over to my car. do you guys have any suggestions?
Old Mar 10, 2004 | 12:20 PM
IntegraBoy04's Avatar
Save your money, and do it right the first time.
Old Mar 10, 2004 | 12:22 PM
Jet Black's Avatar
LS-VTEC will be the only thing that will be worthwhile for you. Gooing b16 will be throwing cash away. You do get more HP, but you have to wait a while for it.
IMO save more cash up and do a proper LS-VTEC or turbo your car.
Old Mar 10, 2004 | 12:26 PM
No's Avatar
No
you sounds like you need too learn alot.I would suggest just too search through different threads.Everyone is going too tell you that you would be a idiot for throwing away your b18 and going too the b16...oh and you said your transmissions match?Yes they do.But a ls tranny with a b16 would be the slowest car ever...Keep your b18b and put a b16 tranny on it
Old Mar 10, 2004 | 12:39 PM
ThePro's Avatar
Only $500 to spend? Forget it. If you are going to do it right then it costs at least $200 in just new belts, seals, and "Oh shtuff! I don't have a tool that can do that! Sears, here I come!" runs.
$500 would be tough to get it done with. PM me and we'll talk about the details. I've done the GS-R swap into my LS. I know the problems..
odz-fab
May 24, 2013 02:04 PM
cmfnelson
Oct 12, 2012 01:20 PM
D15BHatchbackcivic
31
Aug 11, 2005 08:56 AM
SloazzEKhatch
20
Sep 5, 2003 08:49 AM
