engine swap
Old Oct 4, 2007 | 08:39 PM
tylertocker's Avatar
Default engine swap
i have a 91 integra witha b-18a1 and i want to do a swap, but i want to know if i can put any year motor in my car as long as its a b-series. with out changing motor mounts. and i know it has to be cable not hydro.
Old Oct 4, 2007 | 08:43 PM
Default Re: engine swap (tylertocker)
Also how hard is it to do a switch from cable to hydraulic clutch?
Old Oct 5, 2007 | 07:29 AM
dickdragon's Avatar
you could put any b series short block with out changing any motor mounts, reusing a cable b series trans. to work. with the exception of a b20a 2nd gen. prelude. don't forget about you local emissions & regulations.
Old Oct 6, 2007 | 07:29 AM
Default Re: (dickdragon)
so i can just use my old tranny,well get a new one but the same cable. and hook it up to any year short block even if its a hydro clutch? sorry i am pretty new to honda's. still tryin to figure them out.
Old Oct 7, 2007 | 05:56 AM
Default Re: (tylertocker)
Anyone?
Old Oct 7, 2007 | 06:59 AM
pdotjones's Avatar
you can always get the cable to hydro tranny conversion kit.
Old Oct 7, 2007 | 08:24 AM
Default Re: (pdotjones)
would i have to? probably better to do it. but if i am short on cash...just use the same cable tranny right? but i just make sure i got this right. that i can put any year of b-series motor in my 91 integra
Old Oct 7, 2007 | 08:28 AM
BryanM.'s Avatar
Resident Gearhead
If you put a B-series VTEC in your 'Teg and used the B18A tranny you would have uselessly tall gearing. The easiest swap for you would be a 1st gen JDM B16A or the super hard to find B17 (DA) GS-R motor. Both have cable trans.
pleej
Aug 24, 2010 07:35 AM
produca2
Mar 25, 2008 01:50 PM
stemiched
Jun 13, 2007 07:36 PM
808jdm_gsr
Mar 31, 2004 12:25 PM
Kusai.Nihonjin.Desu
Oct 18, 2003 06:57 PM
