Engine squeal...
Old Oct 24, 2001 | 01:13 PM
mattymatt's Avatar
New User
Default Engine squeal...
My engine seems to be squealing... however, not all the time.
On a cold start, occasionally the engine squeals (I guess it's the belts). A friend of mine told me that it might be the bearing on the pulleys that are worn, is this the case? I haven't change the timing belts recently and they don't need to be for a while.
What are the possible reasons, and how could I be rid of this annoying noise?
Old Oct 24, 2001 | 01:28 PM
Web_Head's Avatar
New User
Default Re: Engine squeal... (mattymatt)
Put your ear by your distributor and see if it is coming from there. Could be your water pump. Could be your cam pulleys. Also might be your alternator.
Old Oct 24, 2001 | 01:33 PM
mattymatt's Avatar
New User
Default Re: Engine squeal... (Trench)
Well, the water pump was changed too, so I'm hoping it's not that.
I'll try and pin point the sound, thanks for the tip.
Old Oct 24, 2001 | 01:37 PM
FrostyGSR's Avatar
New User
Try moving all your pulleys side to side with the car off.....if they seem to have play in any of them then it could be a bad bearing.....althogh you've done the WP, check it anyways cuz i've seen defective ones put on before.....tighten your belts as well.....HTH
Old Oct 24, 2001 | 01:43 PM
Comptech98GSR's Avatar
Default Re: Engine squeal... (FrostyGSR)
mine does the same thing when it's cold, but i think it is my pulleys, but i will check everything u all said
Old Oct 24, 2001 | 01:44 PM
samagon's Avatar
90% chance you need new belts.
give them a brief inspection and look to see if there is any cracking or glazing.
Old Oct 24, 2001 | 01:46 PM
mattymatt's Avatar
New User
How exactly do you check the noise from the WP?
Old Oct 24, 2001 | 01:48 PM
samagon's Avatar
Default Re: Engine squeal... (samagon)
oh, you can also (when the car is making the noise) hold a crayon to the belt (basically coating the belt with some wax) if the noise goes away, it is the belt.
also, if you have some extension for your socket/ratchet set (or any other skinny, yet rigid long piece of metal) carefully place it on the area that holds the idler pully, now carefully put your ear on the other end of the ratchet extension, if it is making weird noises the bearings are gone in your idler pulley.
Old Oct 24, 2001 | 01:59 PM
mattymatt's Avatar
New User
On the underside? Or on the top?
Old Oct 24, 2001 | 06:06 PM
Tomakit's Avatar
and if its his cam pulleys, like mine are, would getting a set of aftermarket ones solve the problem?
(id look this up in my helms, but i just saw the thread and im at the computer lab at school, so dont flame me. btw, i hate writing law papers! )
Tom
Old Oct 24, 2001 | 11:04 PM
intekragsr's Avatar
Default Re: Engine squeal... (Tomakit)
Old Oct 25, 2001 | 03:55 PM
mattymatt's Avatar
New User
Default Re: Engine squeal... (intekragsr)
You have mail...
GoodEyeSniper
Apr 10, 2010 04:28 PM
fryman
Aug 22, 2008 10:31 AM
LeonardDB
Nov 9, 2006 06:46 AM
csufweed
Mar 24, 2002 09:15 PM
Spartanic
Jan 16, 2002 08:22 AM
