engine revving away!
Old Sep 3, 2007 | 09:43 PM
wyatt90gs's Avatar
Default engine revving away!
i swapped the head on my 90 teg, b18a, now when i start it the engine just revs up and up to 4500 like wot then it creeps up higher until i shut it off. i have tried the tps and idle air control and im pretty sure all the vacuum lines are hooked up, but now im lost as to what to check next. anybody have any ideas?
Modified by wyatt90gs at 10:53 PM 9/3/2007
Old Sep 4, 2007 | 12:41 AM
91redteg's Avatar
Default Re: engine revving away! (wyatt90gs)
well wut head did u swap for the stock one??
Old Sep 4, 2007 | 03:40 AM
wyatt90gs's Avatar
Default Re: engine revving away! (91redteg)
just anoher stock one, i bought it with the car running like crap and i tested the compression and two cylinders were below 50 so i pulled the head and found two valves with small chunks missing.
Old Sep 4, 2007 | 09:52 AM
95 integra's Avatar
Vacuum leak....air is getting in somewhere. Probably either a leak around the IM gasket or you forgot to plug one of the vacuum ports. Spray carb cleaner around the IM (lots and lots of carb cleaner) and when you hear a change in the pitch, thats where the leak is.
Old Sep 4, 2007 | 10:18 AM
wyatt90gs's Avatar
Default Re: engine revving away! (95 integra)
i'll try that and let you know thanks!!!
Kevs02Accord
Aug 17, 2015 10:33 AM
raider1qaz
Feb 1, 2013 12:44 PM
xluigix47
11
Nov 2, 2012 06:56 PM
PatrickGSR94
11
Mar 30, 2003 11:11 AM
jimby452
Mar 5, 2003 06:20 PM
