engine problem?
Old Feb 6, 2005 | 12:10 PM
dcfour's Avatar
Default engine problem?
i started my car last night, and the motor was revving by its self. The check engine light came on, and then the motor just turned off do you guys know what the problem is?
Old Feb 6, 2005 | 12:29 PM
s2kdre's Avatar
Default Re: engine problem? (dee c four)
sounds like the vaccum line came of the intake or the brake booster.
Old Feb 6, 2005 | 12:34 PM
dcfour's Avatar
Default Re: engine problem? (jdmhonda)
could it be the timing belt? cause i need to change the timing belt soon
Old Feb 6, 2005 | 03:31 PM
pubestripe's Avatar
be a little more specific, what does it idle at? any clanking sounds? what rpm's does it fluctuate between, we more info to help u out.
Old Feb 6, 2005 | 03:47 PM
dcfour's Avatar
Default Re: engine problem? (pubestripe)
at first it idles normal when you barely start your car ... say around 1500, there are no clanking sounds.. and it revvs upto about 3500 and then thats when it just goes down and then dies
Old Feb 6, 2005 | 03:49 PM
pubestripe's Avatar
check all vacuum lines, it sounds like u may have a leak. u throwing any codes?
Old Feb 6, 2005 | 04:49 PM
Acura_I-RS's Avatar
the check engine light is your freind!! get a paperclip bud..
Old Feb 7, 2005 | 06:29 PM
dcfour's Avatar
Default Re: engine problem? (Acura_I-RS)
ok, i have the odb2-code reader and it threw me this code (P1607) Engine Control Module (ECM) - thanks to drag III integra - but yea how can i fix this?
Old Mar 18, 2005 | 09:08 AM
ddeader's Avatar
Default Re: engine problem? (dcfour)
I also have a P1607 DTC on my 2002 Civic HX. How did you correct yours?
SEA ARE EX
20
Jan 10, 2012 05:30 AM
jgrl35
Acura TL, RL & ZDX
Dec 16, 2009 07:45 AM
MtbikingKing
Aug 25, 2005 05:42 PM
wolfpack005
May 12, 2003 10:52 AM
