engine overheating help!!
Old Jan 9, 2003 | 02:26 PM
HmgLauj69's Avatar
Default engine overheating help!!
i recently busted my radiator from jacking my car without a cup on the jack(has this happen to any other one)....just barely replaced it today....but egine temp is not at normal temp(past half and rising)....i installed the radiator myself there's no leak or anything....why is it still overheated??....could i have damage something else when my car droped on the jack??....is there something that blocks the hole(s) of the radiator when it's brand new right out of the box????....someone help!!!
[Modified by HmgLauj69, 12:05 AM 1/10/2003]
Old Jan 9, 2003 | 02:33 PM
Remmy's Avatar
Default Re: engine overheating help!! (HmgLauj69)
make sure you have enough coolant in the system, if it's low on coolant the thermostat wont open up and you'll overheat.
Old Jan 9, 2003 | 02:36 PM
HmgLauj69's Avatar
Default Re: engine overheating help!! (Remmy)
i dont know if i put enough in the radiator but there's plenty in the coolant box....do i still need to and more into the radiator
Old Jan 9, 2003 | 02:50 PM
NeoGSR's Avatar
if the overflow bottle is full it should be okay because the hose in the bottle will suck anything it can if the radiator needed more fluid
maybe the thermostat stuck? just a thought
Old Jan 9, 2003 | 02:56 PM
HmgLauj69's Avatar
Default Re: engine overheating help!! (NeoGSR)
but it brand new though???....is the thermostat inside the radiator??.....if so how would i check it??
Old Jan 9, 2003 | 03:15 PM
Lonny's Avatar
brother had same problem when he drained coolant in his car. He had a air pocket in the radiator and lines. Drive for a couple days and it finally worked the air out.
Old Jan 9, 2003 | 03:22 PM
HmgLauj69's Avatar
Default Re: engine overheating help!! (Lonny)
i'll try that.....but is there any other causes for why my car is still overheating??
Old Jan 9, 2003 | 05:09 PM
Remmy's Avatar
i would add coolant to the radiator itself. the coolant tank on the side fills up the radiator once the thermostat opens up and creates a vacume inside the radiator. it sounds as if your thermostat isnt opening up in the first place, so fill up the radiator till it doesnt take anymore, and then make sure your reserviour tank isnt above the max line.
on a side not, my car was overheating last week after i changed the piston rings/valve seals and the thermostat... what i found to be the cause was that in disconnecting my hoses i spilled a good amount of coolant (to the dissapointment of my parents driveway). the car would overheat after driving it around for a while, and i got a wierd idle and some other oddities. i thought my new thermostat was defective so swapped it out again and still had the same problem. well then it occured that all the stuff i spilled caused there to be air pockets in my liqiud system. the thermostat isnt going to want to open up unless there is fluid in contact with it. i hope this helps to take care of your problem.
Old Jan 9, 2003 | 05:16 PM
Remmy's Avatar
i dunno what year integra you have, but if its a 3rd generation gs-r i can tell you your thermostat islocated behind the distributor and infront of your throtle body. follow the large black hose from the bottom of the radiator up to that area. there is a little housing with an electical clip and ground on it and two 10mm nuts. with a unaversal socket you can take it out no problem and put a new one in for less than 10 bucks and less than a half an hour. don't be a dumbass like me tho, place a catch can or bucket under your car to catch the coolant as it comes out of the hose...or drain your coolant before you do it.
edit: i think its the same however for the all b18 engines, not just the gs-r. also, if all else fails and you need to get from point A to point B without overheating you can take the thermostat out of the housing. this will allow the coolant to flow freely. you will run very cold tho, which isnt great for the engine, but its no where near as damaging as overheating.
[Modified by Remmy, 9:18 PM 1/9/2003]
Old Jan 9, 2003 | 09:23 PM
HmgLauj69's Avatar
Default Re: engine overheating help!! (zetarider)
how would i tell if i have a clog in the radiator?? what can i do to fix it??
Old Jan 10, 2003 | 11:38 AM
Eva01's Avatar
Had my coolant drained and dealer forgot to bleed the system. This caused overheathing w/in 5 min of driving. Just bleed the air out the radiator. I would almost guarantee that is the solution.
Old Jan 10, 2003 | 11:44 AM
94ls's Avatar
how long did it take to install your radiator?
halo2k7
17
Jul 23, 2008 09:57 PM
civicsir94
May 20, 2008 03:21 AM
Shintakun
Honda Civic (2001 - 2005)
Jan 26, 2008 07:44 PM
slikz714
Jul 12, 2006 03:40 AM
94gsr_vtc
12
Jul 26, 2004 08:23 AM
