engine not running properly after swapping valve covers b18a
Old 06-08-2009, 11:24 PM
91integra_rubio's Avatar
Default engine not running properly after swapping valve covers b18a
i just recently painted my valve cover and put it on. After i did so, the car was running very bad. i have the ground on right and i dont see what else i could have messed up. it runs really rough and loud but idles where it should. if i give it gas it revsand then acts like it wants to stall. im really stumped. it seems like its not running on all cylinders. thank you any input would be greatly appreciated.
Old 06-08-2009, 11:31 PM
Ruben19's Avatar
Default Re: engine not running properly after swapping valve covers b18a
make sure you didn't damage the spark plug wires when pulled.
Old 06-09-2009, 04:32 AM
MD426's Avatar
Some times if you pull the plug wires out when they are still warm the connector inside like to come loose or even come off. Make sure they are all crimped on good and make sure you didn't knock any loose from the distributor. Also make sure you didn't knock any vacuum lines lose when you pulled the cover off.
Old 06-09-2009, 07:00 AM
mouab18c1's Avatar
take everything off and redo it..just incase you made a mistake
Old 06-09-2009, 08:54 PM
well i changed the wires and it made it sound and run better but now i have like no power. the wires on the dizzy are in the right order. i know i have some major boost leaks but i mean my cousins lx automatic civic would whoop all over it right now, it seems like it has nothing. could my timing be off and cause this?
Old 06-09-2009, 08:57 PM
Reject Papi
jhammond_82's Avatar
probably two unrelated incidents.
Old 06-09-2009, 10:20 PM
New User
Hondaminican's Avatar
make sure theres no paint where the ground cable goes... sand it down if there is. paint wont let it ground properly
mattv
24
12-12-2007 01:48 PM
awashousky1
09-07-2007 09:42 PM
_Spugen_
21
02-12-2005 02:00 PM
stevescivic
07-26-2004 07:06 PM
bigworm1126
10-28-2003 06:23 PM
Quick Reply: engine not running properly after swapping valve covers b18a
