engine maintence light on and how to refill ac??
like tittle says my integ has the engine maintence lite blinking only the first 3 seoncds when the car is turned on ... and how do u refill an AC? i did it but its not cold? any one know the deal? please pm me if u got the answers. thanks
if you can;t refill it yourself, take it to the shop
you can reset your maintenance light with the maintenance reset button it's under your dash to the right of the wheel column right above where your knee is.
cool ill check up on it tomarrow i mean i know how to refill it but when i do its not cold. and everything is rite and it use to work until i put in new fluid
Well if you put in new Fluid than thats probably your problem because freon is a gas... But if you charge your system and it still isn't cold you probably have a leak.
joemarquis
Aug 16, 2011 07:56 AM
M2B4
Aug 18, 2007 04:41 PM
