ENGINE light!! Help me?!
Ran my GSR at the strip. First run and it COMES on. Hasn't done that until I take it to the REAL drag strip for a test. Still running ok but engine runnin' rough. WHat tha hecks really wrong? timing, wires?
What code is it?
If your idle is rough, one must suspect a bent valve....how high did you rev @ the track? Did you ever misshift?
Need alot more info bud.
What code is it?
Code is key
Code is key
MY BADD!! its 45,73... think its bad fuel injector in cylinder 3, thats the cylinder with a 100 compression!!! but give meeh more inputs if possible
mrem1dipppn
Feb 2, 2012 09:02 AM
Problemo
Mar 18, 2006 10:26 AM
