Engine knock.. vid inside
Old 04-19-2014, 05:03 PM
gfrererr13's Avatar
Default Engine knock.. vid inside
Hey guys,
So... rebuilt my 2001 integra gsr and have had it running great for about 1000km, and then all of a sudden last night on my way home... and it started to do this..
https://www.youtube.com/watch?v=40ei...ature=youtu.be
it doesn't do it all the time, mainly 2500-3000 rpm at idle, and 3500-4000 rpm while driving, it also seems more predominant when at 1/4 throttle...
I have a feeling its something in the bottom end, just looking for a confirmation please.
In the rebuild it got new rod and main bearings, all new seals and gaskets ect...
thanks in advance guys
Old 04-21-2014, 04:35 AM
Tight-R's Avatar
Default Re: Engine knock.. vid inside
Definitely spun a bearing, or a rod end has come loose (doubtful).
- Oil level was at correct point?
- Were the bearing clearances checked during assembly?
- Properly TQ'd?
- Etc
Old 05-11-2014, 03:24 PM
gfrererr13's Avatar
Well you are correct, spun #4 rod bearing.
Everything was installed the best i could, checked clearances, torqued to spec etc.
Took the car 1200km to do this, was running great until this happened... now to make a plan to pull this motor apart again....
Old 05-12-2014, 01:12 AM
m4xwellmurd3r's Avatar
What were your bearing clearences?
GoodSkoolRevltn
10
02-15-2015 05:41 PM
AZNracerx1989
09-05-2006 04:31 PM
projectTeG
20
05-13-2006 01:28 PM
Dyzee
10
04-28-2004 11:56 AM
Random.Hero
04-18-2002 09:27 PM
Quick Reply: Engine knock.. vid inside
