Engine Code HELP
Old Apr 25, 2018 | 08:27 PM
Jacob Downes's Avatar
Default Engine Code HELP
P0700 is whats showing up. A/T what is this? what do i need to do to fix it? Also P1790 says fault location is A/T lock-p clutch not engaging. Probable Cause, wiring, throttle body sensor, which is disconnected right now so this part makes sense. But also says TCM, transmission Control Module. where is this, and how do i fix it? or will that go away once i reconnect the TB sensor? IDK help please
Old Apr 26, 2018 | 05:43 PM
fonkernuckle's Avatar
Default Re: Engine Code HELP
In/on the transmission with the exception being the Engine Coolant Temperature sensor which can cause this CEL. Dirty trans. fluid-when was the last time you changed it? You might want to try a junkyard or different shift solenoid/solenoids. Other than that you are looking at a rebuild. Transmission slipping?
Old Apr 26, 2018 | 06:09 PM
Well the car doesnt start right now which is because I have to get a new distributor but engine scanner only gave me the two codes...once I get it running I will be able to tell if it's slipping. It's also an Auto not Standard
Dave88LX
Dec 7, 2012 02:21 PM
eg9d16turbo
Sep 7, 2011 04:24 PM
EquipedWithVtec
Feb 13, 2008 05:20 PM
CIVILGSR
Jul 20, 2003 10:42 PM
See Are X
Oct 2, 2002 08:14 PM
