Engine Code HELP
P0700 is whats showing up. A/T what is this? what do i need to do to fix it? Also P1790 says fault location is A/T lock-p clutch not engaging. Probable Cause, wiring, throttle body sensor, which is disconnected right now so this part makes sense. But also says TCM, transmission Control Module. where is this, and how do i fix it? or will that go away once i reconnect the TB sensor? IDK help please
In/on the transmission with the exception being the Engine Coolant Temperature sensor which can cause this CEL. Dirty trans. fluid-when was the last time you changed it? You might want to try a junkyard or different shift solenoid/solenoids. Other than that you are looking at a rebuild. Transmission slipping?
Well the car doesnt start right now which is because I have to get a new distributor but engine scanner only gave me the two codes...once I get it running I will be able to tell if it's slipping. It's also an Auto not Standard
eg9d16turbo
Sep 7, 2011 04:24 PM
