Engine code difference?
What is the difference between a b18a an a b18b? Cause im going ls/v and im buying a new oil pump and water pump.... ive got a b18b and im not sure what year car the block would be out of
yea i forgot that part about the B's
I think 98 was the year B18b's became OBD2 because I have a 97 GSR which is OBD1 and 98 was when they change the body
any car, integra or not, is OBDII if its a 96 model year or later. honda got in alot of troubble back in the 90's cause in 96-97 their cars wernt obdII compatable, so they had to do massive recalls to convert.
if you have a 97 GSR, its cause it may have been converted to obd1
other than that, i dont know the difference between b18a and b18b. dcc may have the right idea, all i know is ive got a 95 ls with a b18b in it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveo135 »</TD></TR><TR><TD CLASS="quote">yea i forgot that part about the B's
I think 98 was the year B18b's became OBD2 because I have a 97 GSR which is OBD1 and 98 was when they change the body</TD></TR></TABLE>
A: In 1994 is when they changed from an A1 to a B1. They also increased HP from 130 to 140.
B: You DONT have a 97 GSR that is OBD1!! Unless you converted it, its OBD2A.
C: In 2000 they changed from OBD2A to OBD2B. So 1996-1999 is OBD2A and 2000-2001 is OBD2B
D: The never changed the body of the Integra from 1994 to 2001. They only changed the bumpers and lights in 1998.
Modified by akandok at 11:44 PM 5/8/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akandok »</TD></TR><TR><TD CLASS="quote">
D: The never changed the body of the Integra from 1994 to 2001. They only changed the bumpers and lights in 1998.</TD></TR></TABLE>
well thanks for clearin the OBD thing up for me.. and thats what i meant by the body change.. i guess i should have been clearer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wearyfurball »</TD></TR><TR><TD CLASS="quote">What is the difference between a b18a an a b18b? Cause im going ls/v and im buying a new oil pump and water pump.... ive got a b18b and im not sure what year car the block would be out of</TD></TR></TABLE>
i think the valve covers are different, but im almost sure that almost all the parts are interchangable, but someone correct me if im wrong
the.hamburglar
Dec 30, 2005 08:10 PM
