Endlink help...
Old Dec 13, 2009 | 03:00 PM
langjairicer's Avatar
Default Endlink help...
I am in the process of installing the following parts on my 1994 integra GSR:
Blox LCAs
ASR Subframe Brace
ASR 24mm sway bar
BEAKS lower tie bar
And my problem is : I got the LCAs more or less in place, and I have the subframe brace in place. I then realized that the stock sway bar endlinks will not hold up the sway bar. What endlink set do I need to order that is compatible with the blox LCAs and the 24mm ASR sway bar?
Additionally, where would I order a longer bolt that connects the subframe brace, and LCA pivot point? The added distance from the tie bar and subframe brace does not allow me to screw in the factory LCA pivot point bolt...and i did not receive pivot point screws as additional hardware.
Old Dec 13, 2009 | 04:05 PM
Default Re: Endlink help...
This is what I'm working with . . .
Old Dec 13, 2009 | 04:28 PM
bumping for help
Old Dec 13, 2009 | 06:14 PM
Is this what I need?
http://jhpusa.com/store/pc/viewPrd.a...idproduct=4037
Old Dec 13, 2009 | 07:07 PM
josh-roy's Avatar
Yeah all you need is adjustable endlinks
Old Dec 13, 2009 | 07:18 PM
Cool thanks
Does the BEAKs tie bar install onto the ASR subframe brace...or does it squeeze it self behind the Subframe brace somehow? The long pivot point bolt for the LCAs doesnt seem to be long enough...unless im not doing something right.
Old Dec 14, 2009 | 07:51 PM
Correct me if I'm wrong but is this the correct size bolt I will need to bolt the LCA, subframe brace, and tie bar together? ...
Metric Hex Bolt Steel Grade 10.9, 10mm x 1.5 x 110mm?
Old Dec 20, 2009 | 03:40 PM
Finished it . . .
Couldn't find bolts for the tie bar though.
And yeah, I know, my sway bar bushing fell out. =P
tdhjrh
Apr 5, 2017 05:58 AM
langjairicer
Suspension & Brakes
Dec 20, 2009 09:47 PM
honda_coupe
May 24, 2009 05:04 PM
ilvi3tkidxx
Feb 27, 2009 01:24 AM
stockredej1
Jan 30, 2007 03:58 PM
