Electrical problems need help
Old Nov 23, 2007 | 05:45 PM
WalkerGSR1's Avatar
Default Electrical problems need help
I have a 2000 acura integra gsr. Here's the problem both my front turn signals do not work but the rears do. Also my passenger side high beam doesn't work either. I think there is a short or something. Then today i was driving and and my right turn signal came on and stayed on when i have the head lights on. The right front, rear, and green arrow in the dash stay on now with my head lights i dont even know where to start on fixing this. Can someone help me out?
Old Nov 23, 2007 | 05:54 PM
typeR#0427's Avatar
Default Re: Electrical problems need help (WalkerGSR1)
is the wiring all stock still? i would look for bad connections at the bulbs first. sounds like you might have a short somewhere
Old Nov 23, 2007 | 06:02 PM
WalkerGSR1's Avatar
Yea. They should be, started happening after my turbo kit was installed i think.
Old Nov 23, 2007 | 06:42 PM
typeR#0427's Avatar
Default Re: (WalkerGSR1)
you probably knocked something on accident, i would just trace all the wires down to the bulbs, im sure that its just a loose connection or something.
<------happened to me a couple time
Old Nov 24, 2007 | 12:54 PM
WalkerGSR1's Avatar
I'll try that. Do you have a fuse diagram for 2000 integra gsr? Or do you know where i can get one?
Old Nov 24, 2007 | 03:16 PM
typeR#0427's Avatar
this will cost $4, but probably worth it IMO:
http://www.wirediagram.com/acura.htm
Old Nov 24, 2007 | 07:44 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (typeR#0427)
SOunds like a bad ground because the blinker lights are staying on. Did you remove the from bumper when you did the install. Make sure the ground plugs next to the front bummper are tight. It a clear box with a bunch of wires running to it and it bolted to the car by a 10mm
Ek Steve
13
Jan 14, 2020 07:10 PM
skullbiz
Jan 27, 2010 03:52 PM
jjtreff
Aug 8, 2008 10:06 PM
kasso
Dec 8, 2004 04:49 AM
Ravell
Mar 13, 2002 09:04 AM
