electrical problem. plz help
Old Apr 8, 2011 | 07:22 PM
supra8civic's Avatar
Default electrical problem. plz help
Ok I got a 98 Ls auto sometimes I have problems with it starting and killing the battery ok I took it to advance auto parts and the tested the battery and they said it was a lil low but good and then they tested the alternator and tested it was not charging the battery. Ok so I took the alternator off took to auto zone and they said it was fine but sounded a lil funny so I got a new one put it on and the same the battery it reading 11.87v but now my battery light is on and my speedo is acting all funny sometimes. But it don't seem like its killing the battery fast I and still driving. Fine with it plz help
Old Apr 8, 2011 | 09:02 PM
sik96teg's Avatar
Default Re: electrical problem. plz help
if your bat is reading that low while its on then one of your connections or grounds are jacked up or the ELD in the fuse box under the hood is causing the prob. If its the eld u have to replace the whole fuse box.
Old Apr 8, 2011 | 09:41 PM
mark@silbernage's Avatar
Charged battery should read 12.6VDC when the car is off, and approximately 13.8VDC when the engine is running (and no significant load, such as fans, lights, a/c).
If you are seeing 11.something while it's running, the alternator is not charging.
Old Apr 8, 2011 | 11:33 PM
Ok so eld would stop the alternator from working. Or what would make a new altenator from working. How would I know if the eld is not working if its not throwing. A code
Old Apr 9, 2011 | 09:53 AM
Is there anything else anyone can think of that can be making my car act stupid
Old Apr 11, 2011 | 03:17 PM
Update change out the eld and a few grounds and check it with a halt merger and was reading 13v ok so I started driving it and the battery light keep coming on for a sec and then off again so I took it back to advance auto parts Nd the battery was at 11 again and theay was saying the alternator was not charging the battery again so back to the original problem plz help asap
JohnTuf
Jul 2, 2017 11:14 AM
justin05haex
Jun 25, 2017 08:38 PM
Annihilator
Oct 14, 2009 04:55 PM
ek4ferrio
Aug 29, 2008 10:26 PM
mark_is_gay
Oct 7, 2005 08:20 PM
