electrical problem.
Old Apr 10, 2010 | 10:00 PM
92 CiviC H.B's Avatar
Default electrical problem.
so here is the thing,tranny went bad ,changed it and now the radio,blinkers,clock do not work,its a 93 integra gsr. the hazard lights work but only the left blinker comes on.the fuse is blown,but when i put a new fuse it blows right away,you can see it blow up...what could be my problem here?
Old Apr 10, 2010 | 11:07 PM
vtaker's Avatar
Default Re: electrical problem.
Could be a bad ground. Make sure all wires in the tranny area are connected and not frayed.
Old Apr 11, 2010 | 11:40 AM
the grounds are good. also the door light is on but doors are closed and seat belts fasten,probably going to take the dash off and see what happened.
Old Apr 11, 2010 | 04:41 PM
the door light goes off when i put the light dimmer on off..the light that comes after the sunroof.
Old Apr 13, 2010 | 04:03 PM
found the wire that burned out but cant find where it leads to.i know where it begins but cant find the end..even took the dash out still nothing..i will post a pic of the wire..its blue and white
Old Apr 14, 2010 | 07:39 PM
here is a pic..this wire behind the fuse box is burned out..cant figure out where it goes.if anyone could tell me or even give me a diagram..haynes didn't help..or chiltons.
its the green clip 2nd wire
Old Apr 14, 2010 | 09:17 PM
vtaker's Avatar
I see 4 green clips and I wouldn't know which is second. Can you circle it in microsoft paint then reupload it?
Old Apr 15, 2010 | 02:17 AM
right below the big red one..here
Old Apr 16, 2010 | 08:38 PM
help..
Robinjo
Oct 20, 2010 04:26 PM
flatblack-h22
Mar 25, 2006 08:59 AM
slickyo
Mar 16, 2006 11:06 AM
viva60
Nov 19, 2004 02:19 PM
