EDIT: problem solved
Old Dec 26, 2009 | 06:11 AM
BoostForDinner's Avatar
Default EDIT: problem solved
EDIT: problem solved...the junkyard happened to have one integra that had one banjo bolt left on the brake lines
my 14mm brake banjo bolt stripped on my 94 gsr and the acura dealership is closed today.
my question is would the banjo bolt from a similar year civic caliper be the same size as my teg's? the honda dealership is open until 1pm and i just really dont want to have to wait until monday to fix this.
thanks guys
Old Dec 26, 2009 | 08:27 AM
follie gatts's Avatar
Default Re: need answer quick for brake question please
if the part is the same, it likely has the same part number. i would jump on one of the dealership part sites like acura oem parts dot com and find the part. do the same on a honda site for the civic and see if the part numbers are different. also, search engines will turn up all sorts of fun things to read when you search for part numbers. have fun.
honycutt
Honda Civic (2006 - 2015)
Nov 2, 2011 08:02 AM
GoLowDrew
Mar 31, 2009 11:09 AM
efHatchbackJake
13
Jan 11, 2006 07:34 PM
spock_rocker
21
May 30, 2005 08:40 AM
Paste
15
Nov 28, 2002 09:48 AM
