ecu question
Old Jan 19, 2008 | 01:51 PM
fcfromhell420's Avatar
Default ecu question
my car wont start, i have checked the basics and every things good so i thought it was the ecu so i pulled it out, is it suppose to look like this
its a p30 chipped with neptune
thanks
Old Jan 19, 2008 | 03:33 PM
SammysAuto's Avatar
Default Re: ecu question (fcfromhell420)
Nope that dont look good i would try to replace it and see what happens
Old Jan 19, 2008 | 06:51 PM
iH8RICERZ's Avatar
Default Re: ecu question (SammysAuto)
From the 200+ ecu's I've chipped or had, I've seen about 8 ecu's that has had the same burnt piece. I didn't even bother trying to figure out how to fix it but I know there was a thread about it on the pgmfi forums a while back.
Old Jan 19, 2008 | 06:58 PM
mtber's Avatar
Default Re: ecu question (iH8RICERZ)
It appears that some one removed the burnt transistor which is caused when you mix up your two wire plugs such as evap & intake air temperature.
Check the two wire plugs on your engine harness such as intake air temp & evap to make sure they are not mixed up. Also check the tip of your intake air temperature sensor as it is probably damaged.
The ecu usually does not throw a code when these two are mixed up but it will burn the IAT sensor & burn the trace on the ecu.
Is your fuel pump turning on ?
Do you have spark ?
Old Jan 19, 2008 | 07:46 PM
Default Re: ecu question (mtber)
fuel pump turns on but no spark and the injectors dont open
Old Jan 19, 2008 | 07:53 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcfromhell420 &raquo;</TD></TR><TR><TD CLASS="quote">fuel pump turns on but no spark and the injectors dont open</TD></TR></TABLE>
Is the check engine light on ?
If so, what happens when you jump the two wire service connector ?
drift2004
Feb 27, 2008 01:53 PM
OMG B16
Sep 11, 2006 11:19 AM
PrestonCRX
Mar 16, 2006 06:09 PM
AllMotor12s
Oct 21, 2005 09:17 PM
