ecu problems damn
Old Sep 21, 2009 | 08:52 PM
negro_1087_delta's Avatar
Default ecu problems damn
hey guys i just got a dc2 again the first got stolen but thats off the topic i just got this shell and i put a motor and tranny out of a 96 dc2 donor ls and was driving the car then the car suddenly it shut off and would not fire back up then i swithched to a p28 and started right up o did i menchion that my car is a 94 dc3 the computer that i think crashed was an obd2 p72 that ibought from some guy o and the ecu would not let me go past 5k rpm can any one help i just got this car to replace the car that got stolen
Old Sep 21, 2009 | 09:28 PM
seanbev24's Avatar
Default Re: ecu problems damn
I'm confused, you say you have an obd2 computer plugged into an obd1 car?
Old Sep 21, 2009 | 11:45 PM
djviet2000's Avatar
uhhhh ok. after reading this a few times i kinda get what you saying. well you got your car stolen. you kept the shell and found a dc2 donor car. you put the LS in there and was running a OBD2 P72. it died and you swap a P28 in and it ran fine. ok you can run a OBD1 motor in a OBD2 shell. correct me if i am wrong you gotta have the secondary O2 sensor up and evap system. how did it crash? is there a ground somewhere that isnt grounded right? is it PLUGGED IN ALL THE WAY? there are other factors. how you was driving. did you hit a speed bump?
Old Sep 22, 2009 | 10:28 AM
seanbev24's Avatar
Here's what I get from it, it's a bit hard to read (punctuation would be helpful)... the swap is obd2 from a 96 and the car itself is an obd1 1994, which is why I'm wondering why there was an obd2 p72 hooked up.
If the car is a 94 and still has the obd1 wiring, the OP should just get an obd1 p75 or pr4 ecu. Either will work fine assuming the swap was done correctly.
Old Sep 22, 2009 | 06:35 PM
sorry guys about puctuation but here it goes again its a 94 shell obd1 all the way.
i could not find an obd1 b series ecu so i bought an obd2 ecu then i bought a jumper
oh and my car that got stolen i never found it thats why i bought a shell to try to make up for it
Old Sep 22, 2009 | 07:10 PM
seanbev24's Avatar
Ok, so then you unplugged the jumper, plugged in a p28, and the car started fine? If so, I'd say you narrowed down the problem to the p72 ecu or something in the obd2 jumper wiring.
If you really can't find an obd1 p75 or pr4, maybe you could sell the p72 and jumper harness and use the money to get the p28 chipped, at least with a stock LS basemap
Old Sep 22, 2009 | 07:16 PM
trust and belive that i have tryied that and i really need an ls ecu cause i need to smog the car to register it is there anyone that would trade or let me boroow one ls or p28 chipped
Killer Kham
Mar 19, 2012 08:37 AM
JH4DC231
Nov 11, 2007 07:52 AM
Dc4turbo408
Mar 25, 2005 11:20 AM
Kid1320
Jan 18, 2003 09:14 PM
