ecu problem
Old Apr 5, 2012 | 03:36 PM
ryintegra32's Avatar
Default ecu problem
this is the 4th ecu ive gone threw now. i have a 1991 integra with a b16 in it. it seems that the problem its having is theres no power going to the fuel pump. i plug in my buddies ecu and it fires right up. any ideas on whats causing the problems? thanks 4 all your help
Old Apr 5, 2012 | 03:40 PM
iH8RICERZ's Avatar
Default Re: ecu problem
Which ecu's have you tried so far? Sounds like you need an obd0 pr3/pw0 or convert to obd1 and run a tuned/chipped ecu.
Old Apr 5, 2012 | 03:44 PM
ive had 2 pr3s and 2 chipped p28
Old Apr 5, 2012 | 03:59 PM
iH8RICERZ's Avatar
and what kind of ecu does your buddy have that works on your car?
Old Apr 5, 2012 | 04:16 PM
He has a p72 the car will start right up throw my ecu back in and nothing so I know its not the fuel pump relay.
Old Apr 5, 2012 | 05:07 PM
mouab18c1's Avatar
Have you tried your ecu's on his car?
Old Apr 6, 2012 | 01:24 AM
Yes and it won't start his car either
Old Apr 6, 2012 | 08:29 AM
mouab18c1's Avatar
So you bought four ecus that are ****? Wow! You can ship it out to Chris at Xenocron. He can test and see what is wrong with your ecu.
Check my sig!
Old Apr 6, 2012 | 09:46 AM
el crapitan's Avatar
so did the ecu's that you've tried ever work in your car? like did they work for awhile, then quit?
which injectors are you using?
Old Apr 10, 2012 | 03:44 PM
Ya they worked for awhile and then one day they would jut **** out no warning
Old Apr 10, 2012 | 07:32 PM
somethings frying the ecu's. which injectors are you using? if you're using saturated, you have to ditch the resistor box and rewire, or buy a delete plug.
if you're using peak and hold, you must retain the resistor box.
that can fry an ecu over time
averyvm
Mar 11, 2014 06:06 PM
B16-CRX
Engine Management and Tuning
26
Jul 2, 2011 02:25 PM
I CRX I
Jul 30, 2010 09:15 PM
krazyhmongboi
Feb 21, 2007 06:55 PM
hybridb18
Apr 9, 2004 04:09 AM
