ecu issue
Old Jan 19, 2008 | 05:32 PM
XLR8_HFX's Avatar
Default ecu issue!! please help
i have a p91 ecu that is identicle to a p28.
it was chipped by someone and is using a map that was done when the car was dyno tuned.
the ecu loooks to be done right. i mean its not done cleanly but all the diodes are there.
when i plug it in, the car starts up and works fine for 2 seconds... then after 2-5 seconds the engine light comes on and the car only revs for 3800 rpm. i get an injector code when i look up the cel flashes.
the motor is a 99 gsr wired for obd1. is it because of the dual runner intake manifold with the butterflies????
i really cant figure it out.
here is a post with pictures of the ecu and info.
http://lowmotion.org/viewtopic.php?f=25&t=131492
thanks
Old Jan 19, 2008 | 05:41 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: ecu issue!! please help (XLR8_HFX)
The dueal runner IM has a default for the short runners (high RPM mode). It provides no feedback to the ECU. What code are you receiving?
Old Jan 19, 2008 | 05:45 PM
mtber's Avatar
That ecu looks like it was chipped by some one a long time ago.
The dual runners have nothing to do with the issue you are having.
What exact code is the ecu throwing ?
Old Jan 19, 2008 | 05:49 PM
XLR8_HFX's Avatar
the ecu was chipped 4 months ago. i forgot what code it is exactly. i think it was code 14. it was an injector code. ill look it up now
Old Jan 19, 2008 | 05:51 PM
mtber's Avatar
Default Re: (XLR8_HFX)
Code 14 is an idle air control valve...
XLR8_HFX's Avatar
its code 16 that flashes
Old Jan 19, 2008 | 05:52 PM
mtber's Avatar
Try another ecu and get back to us.
Old Jan 19, 2008 | 05:55 PM
XLR8_HFX's Avatar
um i will have to locate another ecu. i mean if the ecu was bad wouldnt it not start at all. the code im getting is fuel injection code. but when i use my stock obd1 gsr ecu the car works fine
Old Jan 19, 2008 | 07:00 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XLR8_HFX &raquo;</TD></TR><TR><TD CLASS="quote">um i will have to locate another ecu. i mean if the ecu was bad wouldnt it not start at all. the code im getting is fuel injection code. but when i use my stock obd1 gsr ecu the car works fine</TD></TR></TABLE>
There could be a driver in the ecu that is bad.
Old Jan 21, 2008 | 03:37 AM
XLR8_HFX's Avatar
Default Re: (mtber)
i thought it may be a bad burn. i dont know. it seems that the ecu works. just maybe a driver error as you said. i cant see any diodes burnt or traces burnt
egbaby
Mar 7, 2008 11:23 AM
XLR8_HFX
Dec 24, 2007 01:30 PM
erikiksaz1
Jan 17, 2007 10:39 AM
CRXb18Turbo
Oct 20, 2005 05:48 PM
kim_2_da_chee
May 30, 2003 06:18 PM
