ecu help
Old May 4, 2008 | 06:29 PM
E.'s Avatar
E.
Default ecu help
so i have a 2000 acura integra with a jdm type r with a obd2a to obd2b jumper harness. the problem is that the ecu only let me rev to 6500 rpm not to 8500 the rev limit is 6500 could any one help me or have any idea whats going on
Old May 4, 2008 | 06:45 PM
E.'s Avatar
E.
any one
Old May 4, 2008 | 07:01 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: ecu help (E.)
Any CELs? When 6500 RPM is reached, does the engine fall on it's face or is it hitting an electronic limiter?
Old May 4, 2008 | 07:04 PM
E.'s Avatar
E.
is hitting the electronic limiter?
Old May 4, 2008 | 07:06 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (E.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E. &raquo;</TD></TR><TR><TD CLASS="quote">is hitting the electronic limiter?
An electronic limiter is like the typical rev limiter when the engine stutters.
Old May 4, 2008 | 07:08 PM
E.'s Avatar
E.
is there any way i could remove that to to rev to 8500 and when that happen the car loses all the power
Old May 4, 2008 | 07:27 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (E.)
Your VTEC may not be engaging. Can you hear it?
Old May 4, 2008 | 07:37 PM
E.'s Avatar
E.
yeah vtec is engaging but i feel like it loses all power when i hit 6500 i guess that the rev limiter for some reason and it kind of fall all on it's face but as soon i switch gears it gaings all the power again.......... i used my friend ecu and it let me rev pass 6500 with out no problem
Old May 5, 2008 | 04:18 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (E.)
What is the P/N on the ECU? (37820-P73-???) There are no CELs at all?
Old May 5, 2008 | 05:20 AM
E.'s Avatar
E.
Default Re: (Dogginator)
the p/n is 37820-p73-003 what u mean by cels
Old May 5, 2008 | 05:58 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (E.)
CEL = check engine light. Is it illuminated? If so, pull the codes as outlined in the link in the FAQ thread.
Old May 5, 2008 | 09:44 AM
Reego.'s Avatar
it has a engine check light i connected the obd2 computer but it coun't read the codes it say error
Old May 8, 2008 | 05:13 PM
E.'s Avatar
E.
severaltony
Mar 15, 2012 11:23 PM
boostedNOTHARDLY
Dec 8, 2007 10:18 AM
Singlecam4dr
Jan 27, 2007 11:50 AM
fastasscrx
Oct 10, 2005 04:00 PM
BlackCivSi
21
May 4, 2004 08:24 PM
