ECU conversion problem
Old Oct 27, 2006 | 08:30 AM
mastamind's Avatar
Default ECU conversion problem
I tried to use an OBD1 P75 ECU and conversion harness on my 2000 LS. Everything works fine except when I put fuel in the car (My car doesn't want to start after fueling up). I can hear the fuel pump prime but it also makes a strange thumping sound on startup.
Any ideas!
Old Oct 27, 2006 | 08:40 AM
iH8RICERZ's Avatar
Default Re: ECU conversion problem (mastamind)
can you describe the thumbing sound? also, when you plug in your stock ecu now, does it do the same thing or does it fix it?
Old Oct 27, 2006 | 08:00 PM
mastamind's Avatar
When I put the stock ECU back in it fixes the problem. The thumping noise is difficult for me to describe. It's like putting your tongue in the hole of a beer bottle (and putting your mouth over it as well and try to make a popping sound). I'm being serious, no homo.
I guess there's something wrong with my SVE conversion harness. This is the third ECU conversion harness I've had trouble with. I couldn't get skunk2's conversion harness to work without throwing a CEL and now this one is giving me problems.
Modified by mastamind at 9:18 PM 10/27/2006
Old Oct 28, 2006 | 01:12 PM
mastamind's Avatar
I'm off to find a more technical forum.
Nobody replies to threads on this board, rendering it useless. It's ridiculous how my threads a see with no replies.
jdmdohcek98
Dec 28, 2013 09:09 AM
heunde
May 6, 2008 05:01 AM
CMCivicSI
Jan 1, 2006 05:58 PM
