ecu codes? for DA?
Old Jul 2, 2004 | 08:27 PM
lilbluturtle34's Avatar
Default ecu codes? for DA?
i have a engine check light on...its read 12
n 12 is egr i replace it wit one from a junk yard n a new gasket.... n it was reving at 1.5 then it drops then 1.5 n drop then i fix it... bt the engine check light sitll comes on even with the new egr valve?? help??
Old Jul 2, 2004 | 09:13 PM
JiggyKooAndy's Avatar
Default Re: ecu codes? for DA? (lilbluturtle34)
what are you trying to say?
Post that again, and if you honestly want help; taking the time to make sure your post is readable is probably a good idea.
Old Jul 2, 2004 | 09:31 PM
Default Re: ecu codes? for DA? (JiggyKooAndy)
i have a check light.. its reads 12 n 12 is egr valve... i put a new gasket n egr valve.. n it still comes on... i took the negtiive off the batt. to reset it.. n still comes on help??
Old Jul 2, 2004 | 10:45 PM
t . b o z's Avatar
******* SPELL "AND" OUT RIGHT. STOP USING STUNNA TALK.
Old Jul 5, 2004 | 08:57 PM
Default Re: (TimmydaTeg)
aye shut up man..only need help ***.. u dick stfu
Old Jul 5, 2004 | 09:07 PM
..::91TEG-G2::..'s Avatar
Default Re: (lilbluturtle34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilbluturtle34 &raquo;</TD></TR><TR><TD CLASS="quote">aye shut up man..only need help ***.. u dick stfu</TD></TR></TABLE>
your not going to make friend's that way bro... please use proper grammer here too.. dont talk like ur in 5th grade watching blues clues.. we're all grown-up's here.. k?
talk ish again and im goin to report you k? simple as that, and read the guidelines, to help gettin ur *** kicked here in the threads..
now back to ur topic, did you take out the backup fuse in the engine bay fuse box? and let it sit for 10 mins? then plug everything back in?
Old Jul 5, 2004 | 09:40 PM
K.F14's Avatar
Default Re: (..::91TEG-G2::..)
lol noob fight.
sublimenerd
Oct 19, 2006 09:11 PM
Yak BallZ
10
Jul 25, 2005 10:05 PM
mikester_91
Jan 11, 2005 05:20 AM
zCivic
Oct 23, 2004 12:00 AM
mugen-man
Aug 28, 2003 07:12 PM
