E-BRAKE HELP
Old Oct 15, 2003 | 03:14 PM
Gordie's Avatar
Default E-BRAKE HELP
Hey guys,
I have noticed lately that my e-brake handle has more play in it... it rasies are 2 inches before the first click.. before it was like 1inch or so...
so I took the arm rest off and I see the linkages.. there is the large silver peice in the middle that have the 2 wires on it... it seems to be croket not stright.. is this normal?
Thanks
Gordie
Old Oct 15, 2003 | 04:12 PM
tachyteg's Avatar
Default Re: E-BRAKE HELP (Gordie)
yes, they are all crooked.
Old Oct 15, 2003 | 04:33 PM
pro1342's Avatar
Default Re: E-BRAKE HELP (tachyteg)
Adjust the nut on the linkage to pull the cables tighter for a stiffer handle.
Old Oct 15, 2003 | 07:24 PM
WOTTEG's Avatar
Roger, that! Mine's crooked too.
Old Oct 15, 2003 | 10:01 PM
Gordie's Avatar
Default Re: E-BRAKE HELP (WOTTEG)
hhhmmm
aren't the two wires going to rear break lines? shouldn't they be equal,
Also is there another way to tighten but the bolt?
Thanks
Gordie
Old Oct 16, 2003 | 03:47 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gordie &raquo;</TD></TR><TR><TD CLASS="quote">hhhmmm
Thanks
Gordie </TD></TR></TABLE>Yeah, they should be equal, but nothing's ever perfect. If one cable sticks or something, then the other will pull back more. You adjust them so the levers (back on the caliper) are just about at their stops. With age & heat, those springs back at the caliper get weaker as the cable corrodes...
The auto-adjuster is inside the caliper, you can't really adjust that. But it can screw up.
EK_B
27
Aug 14, 2007 08:36 PM
Ep1dem1c
Jul 3, 2007 10:51 AM
Flux
Oct 12, 2006 10:25 AM
JDM4DRACCORD
May 18, 2005 09:44 AM
c1v1c98
Sep 24, 2003 02:24 AM
