DriverSide Headlight is Out..help
Old Jul 14, 2005 | 03:05 AM
Dc2 Powered's Avatar
Default DriverSide Headlight is Out..help
i know its not the bulb i have switch bulbs and try new ones also
the wire got cut someone and when putting it back together it kept slipping and sparking so i though it burnt out the bulb so i try a new one.. nope
then a friend of mine told me the fuse.. but the passenger headlight works..
wouldnt the headlight fuse be for BOTH headlights? someone help!
******* cop gave me a ticket so i need it fix asap!
Old Jul 14, 2005 | 03:24 AM
Deluzional's Avatar
Default Re: DriverSide Headlight is Out..help (Dc2 Powered)
I have a similar problem with my wiring, sometimes 1 headlight will work and the the driverside will be dimmed completely...stupid electrical crap, i hate it. I never found my the real problem either, i just wiggled the wiring around
Old Jul 14, 2005 | 04:06 AM
i used to do that but now the wire is totally cut and i put it back together but no light..
Old Jul 14, 2005 | 04:47 AM
be.twenty's Avatar
L & R headlight fuses are separate
Old Jul 14, 2005 | 05:14 AM
JDM-EJ1's Avatar
Default Re: (99_dc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99_dc &raquo;</TD></TR><TR><TD CLASS="quote">L & R headlight fuses are separate</TD></TR></TABLE>
Also, I would think it may be a ground.. But there may only be one ground for both headlights, not too sure.
Old Jul 14, 2005 | 07:16 AM
xteg95's Avatar
Default Re: (JDM-EJ1)
My passanger side headlight is like that too, and was fixed once by the dealer when the car was new. It would basically just go in and out...I'd have to wiggle it around until it went on...I just got lazy and put the hi-beam lights into the low beam ones
Old Jul 14, 2005 | 08:23 AM
knomexx's Avatar
Default Re: (xteg01)
if one side is dim and the other side still works fine try checking the connector right at the bulb. if you have aftermarket high watt. bulbs ive found they burn the one terminal. Anyone know how to get out of this trial user crap. it wont let me post a picture near my name
jtthwaits
Mar 5, 2011 05:40 PM
Accorddrver
Apr 27, 2004 09:41 AM
Turbo RSX-S
Apr 19, 2004 10:51 PM
OdysseyHF
Feb 8, 2004 11:07 PM
Night Kid
Jan 18, 2002 08:57 AM
