Driver's Water Leak
Old May 24, 2009 | 05:08 PM
NOFX's Avatar
H-T White Ops
Default Driver's Water Leak
I know you guys probably hate to see this again, but I tried searching and found the (apparently more common) passenger side and hatch water leak threads plus a few off the wall suggestions (water through windows and gas door, for example).
A friend of mine is having trouble now.
'98 Integra coupe (with moonroof)
The water comes into the driver's side. It's pooling in the rear passenger foot area, but that is likely because the car is parked almost always on an incline.
That was where it was washed too, and thus the new water being there.
The water also soaked the driver's foot area, but not as badly (again, probably because of the incline the car is parked on). The hatch floor is dry.
Any suggestions? My friend is in a poor mood because of this and I'd really like to help him out, but Integras just aren't my thing.
We can't tear the interior out right now (interior was recently ALL out and saw no immediate problems and now my friend is unwilling to deal with tearing it out right after all that), so I can't check anything right away.
Any suggestions would be greatly appreciated though!
I'll try to list them here:
- Moonroof drain tubes
- Firewall plugs (which ones?)
- Body sealer (ideas on where exactly?)
- Window seals
Cliffs:
- '98 Integra coupe (w/moonroof) has water on driver's side front and rear floor.
- Hatch area is dry.
- Need ideas to help my friend with his car!
Old May 24, 2009 | 09:29 PM
NOFX's Avatar
H-T White Ops
Default Re: Driver's Water Leak
Any suggestions?
Old May 25, 2009 | 01:19 AM
1fstdc2's Avatar
samething happens to me... i thought it was from my feet being wet the first time... but once it happen over and over.. i was wrong..=/ haha
Old May 25, 2009 | 08:39 AM
Spam&Rice's Avatar
My friends yota had a A\C evaporator line leak in the pass. cab might want to check under the dash for any leaks.
also check the widow seal on the out side of the car, the black strip across the outside window make sure its not all crumbled up ont the edges.
GOOD LUCK.....
Old May 26, 2009 | 02:22 PM
NOFX's Avatar
H-T White Ops
GOOD LUCK.....
Well, there is no longer any A/C in this car. Plus the leak is clearly on the driver's side.
Thanks for the suggestion anyway though.
None of the window seals appear damaged or aged enough to cause a leak. There are no cracks.
Old Jun 4, 2009 | 04:06 AM
R-81DC2's Avatar
I have the same problem and it really sucks
Old Jun 4, 2009 | 07:19 AM
Dogginator's Avatar
Daisy... Daisy...
I had an issue with the moonroof drain tube when I relocated my hood latch cable.
Old Jun 4, 2009 | 11:24 AM
NOFX's Avatar
H-T White Ops
Thanks. I'll mention that to him.
I really wish we had known about all of this when the car was torn apart. It would have been much easier to figure this out when the interior wasn't in.
Old Jun 4, 2009 | 11:43 AM
guiltyxxspark's Avatar
I have a similar problem but it was only when I went through the car wash and it was just a few drops but it seems like it was slipping through a crack in the weather stripping. See if his weather strip around the door is damaged or something.
Old Jun 4, 2009 | 04:44 PM
DKYamada's Avatar
i have the same problem. im thinking its coming from the windshield or possibly a crack in the resevor in the front where the water drains down
Old Jul 13, 2009 | 01:00 AM
VoltageBlue00's Avatar
i have had the same problem now for about a year and a half and so far i have found out a few things. the car is a 2000 ls. if you pop the hood and look by the hinges there are some like 1/4" holes, well after i plugged them it stopped on the passengers side and still continued on the drivers side. everything i have found says that you have to pull the fenders, then there are a bunch of spot welds to drill, then when you take this cover off, there isa channel that is supposed to drain the water that runs down the corners of the windshield out and away from the car. if they leak then you have to get them welded.
Old Jul 13, 2009 | 05:40 AM
SpOoLiNg CiViC's Avatar
get your friend to sit in the car with the carpet out. take that car to a carwash and spray the **** out of around the window area to make sure it's not the seals. if not. take it to your house and hit every inch with water hose.
Old Jul 14, 2009 | 12:13 AM
did that today, the water is comming in the corners of each footwell. i thought it had finished on the passengers side but i guess not... i guess i need to learn how to weld??
Old Jul 14, 2009 | 06:02 AM
jb weld. that harden putty. you dont have to just weld it. there are other ways.
Old Jul 15, 2009 | 06:06 PM
well yea that would work i didnt think about that. heres my question, when you pull the fender, theres like 25 - 30 spot welds and then a cover comes off to reveal the leak. how would i attach that cover back on? not just jb weld??
Old Jul 17, 2009 | 06:50 PM
95LS1t's Avatar
bump because i have the same problem!
post pictures if u can of fixing this plz
Old Jul 17, 2009 | 10:02 PM
EK9r!der's Avatar
my friend had a similar problem in his 93 gs. it ended up being that the tube where the sunroof drains was pluged so it would cause the water to overflow then it would leak to the driver side.
check that out, thats most likely the cause of his problem.
Old Jul 17, 2009 | 10:04 PM
EK9r!der's Avatar
here i found this, this is basicaly the same concept but on the rear drivers side.
http://www.team-integra.net/sections...?ArticleID=546
mcd7
Jan 21, 2012 11:33 AM
bad 91 teg
33
Oct 1, 2011 02:34 PM
biscuit01ex
Honda Civic (2001 - 2005)
Apr 30, 2006 11:20 PM
Truecure
Nov 3, 2004 12:33 PM
crxaddikt
Oct 28, 2002 02:35 PM
