drivers side driveshaft ??
Old Jan 4, 2004 | 12:39 AM
JBBNJ609's Avatar
Default drivers side driveshaft ??
hey so i bought a autozone type driveshaft for cheap with a lifetime warrenty and i took out my old one , and i only bought the outer part of the drivers side driveshatf , now i have to detatch the inner part off the old one , how do i do that , i cant get it off by pulling on it ??
Old Jan 4, 2004 | 12:48 AM
everidge4's Avatar
Default Re: drivers side driveshaft ?? (jason bouchard)
with a pry bar or big screw driver
Old Jan 4, 2004 | 01:12 AM
JBBNJ609's Avatar
Default Re: drivers side driveshaft ?? (crackalackin)
i dont have a play to get leverage or to "pry"
Old Jan 4, 2004 | 02:22 AM
everidge4's Avatar
then set it flat on the ground maybe even duck tape it to the floor so it dont roll real easy get a big screw driver and tap it in with a hammer and twist the screw driver then you can get it from there
and yeah thats a good ida to go ahead and pull my tranny do you know if it will come out without pulling my motor
Old Jan 4, 2004 | 04:51 AM
JBBNJ609's Avatar
read your other thread , i posted
Old Feb 1, 2004 | 05:17 AM
JBBNJ609's Avatar
i still cant remove my inner shaft from the outer shaft , how do i remove it , its nto workign please help
thanks
Old Feb 1, 2004 | 06:29 AM
IN VTEC's Avatar
Use a small sledgehammer. Give it a good wack on the inboard joint. It'll pop out. Forget all that prying stuff...you'll poke your eye out.
Old Feb 1, 2004 | 11:39 PM
JBBNJ609's Avatar
Default Re: drivers side driveshaft ?? (IN VTEC)
im still trying and nothing is working i even hit it with pbc blaster
Old Feb 2, 2004 | 12:57 AM
JBBNJ609's Avatar
i need to have them seperated by tommarrow please help , its not budging even when hitiing it , where should i hit it btw ??
thanks
JAY
Old Feb 2, 2004 | 08:09 AM
JBBNJ609's Avatar
**** it , i brought it to a place and they took it apart for free . they wouldnt tell me how they got it off though ,but took them about 10 mins or so
johnnyabq
Honda CR-V & Element
Aug 29, 2012 07:48 PM
ep3,lover
Jan 11, 2012 10:52 PM
Ldo
Sep 16, 2008 12:20 PM
CRseXy
Nov 22, 2004 08:09 AM
Sassafrass
Apr 24, 2003 11:40 AM
