Driver side power window issue
Hey guys,
I have a 94 integra, and I'm having an issue with power window. The passenger side works fine, and I've replaced the motor. I've put +12V and -12V to the motor, and the motor works fine. I replaced the switch with another one that was pulled out of my friend's car that worked fine. I have 12V going into the switch, and I get +12V and -12V out of the pin going to the motor. Once I plug in the 4 pin connector and try the switch, it doesn't work. I unplug the 4 pin connector to measure the output voltage from the switch, and now the switch is only outputting +2V and -2V. I'm at a loss to why the voltage drops. I'm getting power to the switch and to the motor, but when I plug it in and try to use it, it loses voltage. And again I put 12V directly to the motor and it works fine.
Any ideas?
Any ideas?
