Double Nutting
Old Apr 30, 2005 | 05:26 PM
95GSRTT
Guest
Posts: n/a
Default Double Nutting
I was wondering if someone could explain to me double nutting your bolts on to your head studs. I got a stud that for the life of me while not come out, and the alan socket part is doing me any good, so i figured maybe double nutting them out will work.
Thanks
Old Apr 30, 2005 | 07:14 PM
Muckman's Avatar
Moderator in Chief
Default Re: Double Nutting (95GSRTT)
You thread 2 nuts onto a bolt and then thread them towards each other, tighen the top one and loose the bottom one at the same time. This locks them together and then you can use them to tighten or loosen the bolt.
Old Apr 30, 2005 | 07:35 PM
95GSRTT
Guest
Posts: n/a
Default Re: Double Nutting (Muckman)
Ya that didnt work at all. My guess is b/c the person who installed it either Loctited it or torqued it down to 600 lbs of torque. It has already snapped off an alan socket when i was using my 1/2" wrench. Anyone have another idea? I dont wanna strip the hex.
Old Apr 30, 2005 | 07:42 PM
Kendall's Avatar
I'm thinking loctite. Overtorquing it would have just stripped it out (damn aluminum). Have you tried breaking it loose with a fifteen foot long pipe? Give it a quick jerk as gradual pressure often leads to breaking things.
Old Apr 30, 2005 | 09:14 PM
95GSRTT
Guest
Posts: n/a
Default Re: (Kendall)
i tried it with a 2 foot one, and then i tried it with an impact wrench, but didnt give it much power b/c i was afraid of stripping it. Are machine shops able to get these out?
Id rather be able to get it out using this double nutting thing, but i dont get how it works. Put one upside down on it, then put another one on it right side up, tighten them against each other, but either way you are trying to turn the stud the same way as the bolt, so my bolt always breaks free 1st.
Old Apr 30, 2005 | 09:18 PM
mr.beeks's Avatar
Default Re: (95GSRTT)
for gods sake there are kids on here that dont need to hear this
type of things......
Old Apr 30, 2005 | 09:21 PM
95GSRTT
Guest
Posts: n/a
Default Re: (mr.beeks)
LOL
Old Apr 30, 2005 | 10:04 PM
stumpyf4's Avatar
If it's loctite use a bit of heat to loosen the strength of the loctite.
Old May 1, 2005 | 07:14 AM
sabotage7's Avatar
Default Re:
haha, i just had to look in here bc of the title! good luck!
bobbyeg6
Apr 26, 2010 04:11 AM
STROHM
Mar 12, 2009 09:03 PM
tpot90
Apr 5, 2008 09:46 AM
See Are X
Feb 6, 2003 12:31 AM
syndicate43
Nov 25, 2002 05:49 PM
