Door upgrade
Door upgrade
First I did a search and there was zero useful information.
My question is how do you swap 98+ integra doors onto a 95. My 95 has only power windows and a nasty dent on one of the doors. I want to swap over the doors and get the door locks working.
I was told that the harnesses and plugs between the two styles ae different and that it needs to be repinned, also i need to locate the stock relay for the power brakes under the dash form the 98+.
Has anyone does this or have reliable information on how to do it?
Night Owl
1 Post
Re: Door upgrade (the_grinder)
Your best bet is going to be to switch over the wiring( guts) from the old doors. This is what I had to do to swap 00 ITR doors onto my 95 rs. Good luck
Re: Door upgrade (shutupnskate)
Yeah I was thinking the same thing but my RS never came with power door locks, so changing over the guts is not really an option.
Do you or anyone else know about manually wiring the doors together or repinning the harnesses.
As a last result I was thinking to get aftermarket door locks installed.
hmm I have the same problem (with the dent on my door) and was looking to switch over too, how hard is this process? any write ups?
