door doesn't close
Old Mar 11, 2004 | 08:07 AM
powerls's Avatar
Default door doesn't close
when I am driving around turns or going over bumps, my "door is ajar" symbol flickers on and off. I can also push down on the arm rest on the door and the symbol will light up. Also, my dome light will flicker on and off. It kinda gives my car a cool techno feel sometimes (J/K). Has anyone else had this happen?
Old Mar 11, 2004 | 08:16 AM
SuzukaBlueAP2's Avatar
Default Re: door doesn't close (powerls)
sounds like the switch at the bottom of the door jam is messed up. Could be a loose wire or the switch might be bent.
Old Mar 11, 2004 | 09:32 AM
purplegsr's Avatar
I had that happen in my old 91 EF hatchback. It was pretty funny, I think the driver's side door was jacked up to the point that the sensor would trick itself if i hit a bump. I just turned the dome light to 'OFF' instead of 'DOOR' and I just learned to deal with the seatbelt sign coming on at random moments.
Mine was probably due to an accident, so the door wasn't flush with the rest of the car, and I rolled around on Neuspeed Race, kinda bumpy ride.
Old Mar 11, 2004 | 09:34 AM
powerls's Avatar
yeah I have the dome light off now, but I really want to just fix it.
Old Mar 11, 2004 | 09:35 AM
svtec's Avatar
L D E S
Default Re: door doesn't close (purplegsr)
my trunk light used to blink in my civic coupe.
i always wanted that bastard to fly open on the interstate, but it never did.
Old Mar 12, 2004 | 07:16 AM
mackgsr's Avatar
my 95 dc2 does the same ****, ill be smashin at like 90 or 100 mph and the damn light will start blinkin its like my door is off track or sumthin, its gay as hell
Old Mar 12, 2004 | 08:19 AM
swanny's Avatar
Default Re: door doesn't close (mackgsr)
Try adjusting your striker (on the door jamb) Make sure it is hitting the latch square. Or you could try replacing the switch.
gdrew888
Jan 11, 2013 06:13 AM
lmike6453
Sep 18, 2008 05:21 AM
draperj09
May 14, 2008 08:01 PM
951dc5
Jun 14, 2007 10:19 PM
maxburnout
Nov 30, 2004 09:39 PM
