this dont look right - gsr head - possible crack w/pics
i just bought this head last night and on the passender/distributor side it seems like it is cracked or has a hole on the bottom of the head. i assume that this is above where the coolant will flow so this is not a good situation. think i can have the machine shop weld it shut or make a tiny aluminum piece and weld it??? i really dont wanna be a dick to the guy i got it from and MAKE him gimme my money back - i would rather keep the head if i could get it easily fixed. thanks
obd1 gsr head complete minus distributor, skunk2 gears, earlier blox IM
Re: this dont look right - gsr head - possible crack w/pics
It's just an oil drain-hole. I'll bet you've got another one just like it at the other end of the head.
There's quite a lot of casting-flash in that hole.
thanks!! whew!!!
the one on the other end actually DOES look like part of the casting but the one in uestion looks like a piece of metal went flying thru. its been 6 years since i had a dohc build and i was worried this morning after i took a good look at the head so i figured this is the best place to start as always. thanks Tegger
eh2_Trav
Welding / Fabrication
02-11-2019 05:42 PM
eh2_Trav
Engine Machining & Assembly
01-27-2019 09:51 AM
eh2_Trav
Transmission & Drivetrain
01-21-2019 11:00 AM
hb_guy
12-07-2011 04:42 AM
