Dome light not turning on
Old Apr 25, 2012 | 12:26 AM
user 8508202243's Avatar
Default Dome light not turning on
My dome light is not working when i switch it to the "on" position but the "door open" and "off" does work good. Any ideas on how to fix this problem? The bulb is not burned out.
Old Apr 25, 2012 | 05:36 AM
fcm's Avatar
fcm
Old Fart
Default Re: Dome light not turning on
What do you mean "the door open and off does work"?
If you mean the dome light works when you open a door and you can turn the dome light off completely, then the problem is the switch ot the ground for the switch. 94
Old Apr 25, 2012 | 08:10 AM
MechEng's Avatar
I have the same problem:
Works when doors is "OPEN"
When I try to "manually" turn the light on it does not turn on.
Old Apr 25, 2012 | 08:17 AM
zerovandez's Avatar
This would lead me to believe that the switch on the light is your problem.
Old Apr 25, 2012 | 08:21 AM
stowne78's Avatar
X2
Old Apr 25, 2012 | 08:26 AM
stowne78's Avatar
Edited: I wasn't thinking when i wrote that. You have to take the switch out, put the meter on both terminals, then check for contnuity
Old Apr 25, 2012 | 10:49 AM
TheRealTegger's Avatar
If you move the switch from Door Open to On verrry slowly, can you make the light come on? What if you work the switch back and forth rapidly, many many times?
Also: pop the cover off and have a look for a Philips-head screw set into a silver tab. If you see an open hole instead, that may be the cause. That screw is one of the grounds for the "on" setting.
Old Apr 25, 2012 | 03:28 PM
No it won't turn on when switched to the "on" setting but i haven't tried what you said yet. Is the switch the same in a 2001 teg?
Old Apr 25, 2012 | 04:42 PM
fcm's Avatar
fcm
Old Fart
Dome lights on all Integra are the same, [work the same way] 12V+ is supplied directly to the light bulb, the 3 position switch connects the ground for the bulb to either a direct ground, [dome light mounting screw] the door pins or not ground for off.
As mentioned, pop the cover off and check the mountiing screw going through the metal "tab", if ther is no screw, install one, if ther is a screw, make sure it is tight. 94
Old Apr 25, 2012 | 08:58 PM
Well i looked at the screw that grounds the light bulb but it's already tight so i guess it's the switch itself that has gone bad
Old Apr 26, 2012 | 04:20 AM
I guess. But I'm not seeing how, unless somebody's punched the switch and broken the white plastic the pins are set into. These switches are very durable and well-made.
Why don't you remove your entire dome light and disassemble it? If it's broken, you'll be able to tell right away. You will need a very tiny electronics-type Philips screwdriver for the tiny screws on the top off the assembly. And watch out for a couple of little springs which can zing out and get lost!
But before you do that, try using a piece of wire or a paper clip to jump the silver tab on the inboard side of the bulb to the big Philips screw. Does the light come on now?
Old Apr 26, 2012 | 09:10 AM
zerovandez's Avatar
Why go through all of the hassle? They're pretty cheap on ebay. I just saw one for 5 bucks shipped. Not a bad investment.
Old Apr 26, 2012 | 11:00 PM
Where's the fun in that? I'd rather pull apart the affected unit, see how it works, and try and fix it. (Observant readers will be able to guess that I've already done that...)
Old Apr 27, 2012 | 06:31 AM
MechEng's Avatar
Agreed! I'll try this shortly and report back.
Old Apr 27, 2012 | 09:57 AM
But first jump those two connectors, as I said above. You can do this without removing the light from the roof.
Old Apr 29, 2012 | 03:33 PM
MechEng's Avatar
Bingo, fixed! My screw was missing. No where to be found, put in a new screw. THANKS, appreciated!!
mdh111
Dec 6, 2016 11:40 PM
lpdrumer
Feb 20, 2011 04:25 PM
bigslimdog
Sep 4, 2005 09:49 AM
01Blackerado
Audio / Security / Video
Jul 22, 2005 05:59 PM
desync
Oct 5, 2002 02:19 PM
