does the hbrace really work?
Old Apr 30, 2006 | 03:47 PM
mrrugsr's Avatar
Default does the hbrace really work?
just wondering if i should put this on or not. i already hav it, came with a package i bought. it will be tuff to route my 3" exhaust through but if it WILL stop wheel hop then ill do it. i bought new motor mounts with mount inserts so i hope that helps. should i pt this on or toss it
Old Apr 30, 2006 | 04:28 PM
aznsins88's Avatar
personally id say toss it.when i had it i didnt feel much difference anywhere and after a month or so the welds cracked on me.but do wat u want.just my personal experiance.
Old Apr 30, 2006 | 04:35 PM
CNSK's Avatar
Default Re: does the hbrace really work? (mrrugsr)
motor mounts and traction bar should stop your wheel hop.....
Old May 1, 2006 | 10:15 AM
jonshonda's Avatar
Community Builder
if your car is lowered, you will tear the **** out of that thing. got one for my civic with 2.5" drop and that thing scraped everywhere
Old May 1, 2006 | 10:21 AM
debogsr's Avatar
Default Re: (jonshonda)
that thing is a POS. I had it on and eventially it broke the tac welds where the front LCA's are. I had to dremel through the subframe just to get to where the tac welded bolt was to get a wrench on it to tighten it back up. It didnt do much for me, and scrapped everywhere. It also made changing oil harder.
Old May 1, 2006 | 10:46 AM
SlamminS85's Avatar
Default Re: (debogsr)
harder?? its already impossible to change the oil without getting dirty, thats teh oen thing i wish honda used from toyota, oil filter placement
Old May 1, 2006 | 01:45 PM
debogsr's Avatar
Default Re: (SlamminS85)
i mean harder as in the H brace goes right where you hand reaches up to get the filter. You can get around it, but not when the cat is hott.
Old May 2, 2006 | 03:29 PM
dwolsten's Avatar
There's one other thing Honda could learn from Toyota: how to design hubs so that you can replace wheel lugs without having to take anything apart. I did this once on a '90 Corolla and it was easy: jack up the corner of the car, take off the wheel, and then just rotate the hub so the bad stud is lined up with a cut-out, and hammer out the stud.
teddy_dc2
May 2, 2006 10:32 PM
CpRiCe87
13
Mar 27, 2006 07:37 PM
elitesi8
Oct 9, 2005 06:42 AM
jbscivichb92
Oct 29, 2004 07:49 AM
SamC
Apr 10, 2002 01:11 PM
